Where is the code in efxclipse 3.0.0 that creates the e(fx)clipse project? [message #1770062] |
Tue, 08 August 2017 01:33 |
Marcelo Ruiz Messages: 80 Registered: April 2017 |
Member |
I would like to create a new project wizard that will generate different kind of bundles with their test bundles. I am planning on using the great example that Tom provided for testing E(fx)clipse applications (thanks again Tom!).
For example, I would like to generate:
- a new type of project for a non-ui plugin that will also generate the junit test fragment plugin
- a new type of project for ui plugins that will generate the junit+testfx test fragment plugin
- a new type of project for ui integration that will generate the testfx test plugin
I was also thinking, once I have figure exactly how things work, to generate content for the the different components of the MVVM pattern, or the PMVC one.
Since I have zero experience with SWT and Eclipse, I would appreciate if someone points me to the right direction. I have been able to find some old tutorials online, but they were for Eclipse 3.x.
I also tried looking at the E(fx)clipse github page, but some things I found had references to Jemmy, so I think I am not looking into the right place.
Thanks!
FUDForum. Page generated in 0.03770 seconds
