Home » Eclipse Projects » Eclipse Scout » Creating new Scout project (Oxygen Scout)
Creating new Scout project [message #1769990] |
Mon, 07 August 2017 10:35 |
I just installed Eclipse Scout Oxygen with the install package downloaded by eclipse site for windows 7 64bit, and everything works fine.
After I try to create a new scout project but return to me the following errors (see below).
Can someone help me?
[SEVERE]: Unable to create Scout Project.
org.eclipse.core.runtime.CoreException: Unable to create Scout Project.
at org.eclipse.scout.sdk.s2e.operation.project.ScoutProjectNewOperation.run(ScoutProjectNewOperation.java:100)
at org.eclipse.scout.sdk.s2e.job.ResourceBlockingOperationJob.run(ResourceBlockingOperationJob.java:112)
at org.eclipse.scout.sdk.s2e.job.AbstractResourceBlockingJob.execute(AbstractResourceBlockingJob.java:64)
at org.eclipse.scout.sdk.s2e.job.AbstractJob.runInternal(AbstractJob.java:107)
at org.eclipse.scout.sdk.s2e.job.AbstractJob.run(AbstractJob.java:71)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: org.eclipse.scout.sdk.core.util.SdkException: org.eclipse.core.runtime.CoreException: Maven build failed with error code 1. See Maven Console for details.
at org.eclipse.scout.sdk.s2e.operation.MavenBuildOperation$M2eMavenRunner.execute(MavenBuildOperation.java:351)
at org.eclipse.scout.sdk.core.s.util.maven.MavenRunner.execute(MavenRunner.java:49)
at org.eclipse.scout.sdk.core.s.project.ScoutProjectNewHelper.createProject(ScoutProjectNewHelper.java:128)
at org.eclipse.scout.sdk.s2e.operation.project.ScoutProjectNewOperation.run(ScoutProjectNewOperation.java:90)
... 5 more
Caused by: org.eclipse.core.runtime.CoreException: Maven build failed with error code 1. See Maven Console for details.
at org.eclipse.scout.sdk.s2e.operation.MavenBuildOperation.run(MavenBuildOperation.java:135)
at org.eclipse.scout.sdk.s2e.operation.MavenBuildOperation$M2eMavenRunner.execute(MavenBuildOperation.java:348)
... 8 more
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building Maven Stub Project (No POM) 1
[INFO]
[INFO] >>> maven-archetype-plugin:2.4:generate (default-cli) > generate-sources @ standalone-pom >>>
[INFO]
[INFO] <<< maven-archetype-plugin:2.4:generate (default-cli) < generate-sources @ standalone-pom <<<
[INFO]
[INFO] --- maven-archetype-plugin:2.4:generate (default-cli) @ standalone-pom ---
[INFO] Generating project in Batch mode
[WARNING] Error reading archetype catalog http://repo.maven.apache.org/maven2
org.apache.maven.wagon.TransferFailedException: Failed to transfer file: http://repo.maven.apache.org/maven2. Return code is: 400
at io.takari.aether.wagon.OkHttpWagon.fillInputData(OkHttpWagon.java:78)
at org.apache.maven.wagon.StreamWagon.getInputStream(StreamWagon.java:116)
at org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:88)
at org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61)
at org.apache.maven.archetype.source.RemoteCatalogArchetypeDataSource.downloadCatalog(RemoteCatalogArchetypeDataSource.java:119)
at org.apache.maven.archetype.source.RemoteCatalogArchetypeDataSource.getArchetypeCatalog(RemoteCatalogArchetypeDataSource.java:87)
at org.apache.maven.archetype.DefaultArchetypeManager.getRemoteCatalog(DefaultArchetypeManager.java:216)
at org.apache.maven.archetype.DefaultArchetypeManager.getRemoteCatalog(DefaultArchetypeManager.java:205)
at org.apache.maven.archetype.ui.generation.DefaultArchetypeSelector.getArchetypesByCatalog(DefaultArchetypeSelector.java:200)
at org.apache.maven.archetype.ui.generation.DefaultArchetypeSelector.selectArchetype(DefaultArchetypeSelector.java:71)
at org.apache.maven.archetype.mojos.CreateProjectFromArchetypeMojo.execute(CreateProjectFromArchetypeMojo.java:181)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[WARNING] No archetype found in remote catalog. Defaulting to internal catalog
[INFO] Archetype repository not defined. Using the one from [org.eclipse.scout.archetypes:scout-helloworld-app:6.0.0.RC4 -> http://repo1.maven.org/maven2/] found in catalog local
[INFO] Downloading: http://repo1.maven.org/maven2/org/eclipse/scout/archetypes/scout-helloworld-app/7.0.0.008_Oxygen/scout-helloworld-app-7.0.0.008_Oxygen.jar
[INFO] Downloading: https://repo.maven.apache.org/maven2/org/eclipse/scout/archetypes/scout-helloworld-app/7.0.0.008_Oxygen/scout-helloworld-app-7.0.0.008_Oxygen.jar
[INFO] BUILD FAILURE
[INFO] Total time: 2.945 s
[INFO] Finished at: 2017-08-07T13:03:02+02:00
[INFO] Final Memory: 14M/170M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:2.4:generate (default-cli) on project standalone-pom: The desired archetype does not exist (org.eclipse.scout.archetypes:scout-helloworld-app:7.0.0.008_Oxygen) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Thanks in advance for any help and explanation
[Updated on: Mon, 07 August 2017 11:04] Report message to a moderator
Re: Creating new Scout project [message #1770001 is a reply to message #1769994] |
Mon, 07 August 2017 12:24 |
Hi Matthias,
I'm able to download without problem this file from the link present in your post ... There is a way to say to Eclipse Oxygen or to Maven to take this file from my HD?
I also checked in Maven's console the error with this command "mvn -e" and the result is shown below. Unfortunately, I'm not so familiar with Maven console and his messages.
I hope can help to understand my problem
Apache Maven 3.3.9 (bb52d8502b132ec0a5a3f4c09453c07478323dc5; 2015-11-10T17:41:47+01:00)
Maven home: C:\apache-maven-3.3.9
Java version: 1.8.0_121, vendor: Oracle Corporation
Java home: C:\Program Files\Java\jdk1.8.0_121\jre
Default locale: it_IT, platform encoding: Cp1252
OS name: "windows 7", version: "6.1", arch: "amd64", family: "dos"
[DEBUG] Created new class realm maven.api
[DEBUG] Importing foreign packages into class realm maven.api
[DEBUG] Imported: javax.enterprise.inject.* < plexus.core
[DEBUG] Imported: javax.enterprise.util.* < plexus.core
[DEBUG] Imported: javax.inject.* < plexus.core
[DEBUG] Imported: org.apache.maven.* < plexus.core
[DEBUG] Imported: org.apache.maven.artifact < plexus.core
[DEBUG] Imported: org.apache.maven.classrealm < plexus.core
[DEBUG] Imported: org.apache.maven.cli < plexus.core
[DEBUG] Imported: org.apache.maven.configuration < plexus.core
[DEBUG] Imported: org.apache.maven.exception < plexus.core
[DEBUG] Imported: org.apache.maven.execution < plexus.core
[DEBUG] Imported: org.apache.maven.execution.scope < plexus.core
[DEBUG] Imported: org.apache.maven.lifecycle < plexus.core
[DEBUG] Imported: org.apache.maven.model < plexus.core
[DEBUG] Imported: org.apache.maven.monitor < plexus.core
[DEBUG] Imported: org.apache.maven.plugin < plexus.core
[DEBUG] Imported: org.apache.maven.profiles < plexus.core
[DEBUG] Imported: org.apache.maven.project < plexus.core
[DEBUG] Imported: org.apache.maven.reporting < plexus.core
[DEBUG] Imported: org.apache.maven.repository < plexus.core
[DEBUG] Imported: org.apache.maven.rtinfo < plexus.core
[DEBUG] Imported: org.apache.maven.settings < plexus.core
[DEBUG] Imported: org.apache.maven.toolchain < plexus.core
[DEBUG] Imported: org.apache.maven.usability < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.* < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.authentication < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.authorization < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.events < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.observers < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.proxy < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.repository < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.resource < plexus.core
[DEBUG] Imported: org.codehaus.classworlds < plexus.core
[DEBUG] Imported: org.codehaus.plexus.* < plexus.core
[DEBUG] Imported: org.codehaus.plexus.classworlds < plexus.core
[DEBUG] Imported: org.codehaus.plexus.component < plexus.core
[DEBUG] Imported: org.codehaus.plexus.configuration < plexus.core
[DEBUG] Imported: org.codehaus.plexus.container < plexus.core
[DEBUG] Imported: org.codehaus.plexus.context < plexus.core
[DEBUG] Imported: org.codehaus.plexus.lifecycle < plexus.core
[DEBUG] Imported: org.codehaus.plexus.logging < plexus.core
[DEBUG] Imported: org.codehaus.plexus.personality < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.Xpp3Dom < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlPullParser < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlPullParserException < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlSerializer < plexus.core
[DEBUG] Imported: org.eclipse.aether.* < plexus.core
[DEBUG] Imported: org.eclipse.aether.artifact < plexus.core
[DEBUG] Imported: org.eclipse.aether.collection < plexus.core
[DEBUG] Imported: org.eclipse.aether.deployment < plexus.core
[DEBUG] Imported: org.eclipse.aether.graph < plexus.core
[DEBUG] Imported: org.eclipse.aether.impl < plexus.core
[DEBUG] Imported: org.eclipse.aether.installation < plexus.core
[DEBUG] Imported: org.eclipse.aether.internal.impl < plexus.core
[DEBUG] Imported: org.eclipse.aether.metadata < plexus.core
[DEBUG] Imported: org.eclipse.aether.repository < plexus.core
[DEBUG] Imported: org.eclipse.aether.resolution < plexus.core
[DEBUG] Imported: org.eclipse.aether.spi < plexus.core
[DEBUG] Imported: org.eclipse.aether.transfer < plexus.core
[DEBUG] Imported: org.eclipse.aether.version < plexus.core
[DEBUG] Imported: org.slf4j.* < plexus.core
[DEBUG] Imported: org.slf4j.helpers.* < plexus.core
[DEBUG] Imported: org.slf4j.spi.* < plexus.core
[DEBUG] Populating class realm maven.api
[INFO] Error stacktraces are turned on.
[DEBUG] Reading global settings from C:\apache-maven-3.3.9\conf\settings.xml
[DEBUG] Reading user settings from C:\Users\vimgiudi\.m2\settings.xml
[DEBUG] Reading global toolchains from C:\apache-maven-3.3.9\conf\toolchains.xml
[DEBUG] Reading user toolchains from C:\Users\vimgiudi\.m2\toolchains.xml
[DEBUG] Using local repository at C:\Users\vimgiudi\.m2\repository
[DEBUG] Using manager EnhancedLocalRepositoryManager with priority 10.0 for C:\Users\vimgiudi\.m2\repository
[DEBUG] Extension realms for project org.apache.maven:standalone-pom:pom:1: (none)
[DEBUG] Looking up lifecyle mappings for packaging pom from ClassRealm[plexus.core, parent: null]
[INFO] Total time: 0.101 s
[INFO] Finished at: 2017-08-07T14:30:10+02:00
[INFO] Final Memory: 7M/309M
[ERROR] No goals have been specified for this build. You must specify a valid lifecycle phase or a goal in the format <plugin-prefix>:<goal> or <plugin-group-id>:<plugin-artifact-id>[:<plugin-version>]:<goal>. Available lifecycle phases are: validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy, pre-clean, clean, post-clean, pre-site, site, post-site, site-deploy. -> [Help 1]
org.apache.maven.lifecycle.NoGoalSpecifiedException: No goals have been specified for this build. You must specify a valid lifecycle phase or a goal in the format <plugin-prefix>:<goal> or <plugin-group-id>:<plugin-artifact-id>[:<plugin-version>]:<goal>. Available lifecycle phases are: validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy, pre-clean, clean, post-clean, pre-site, site, post-site, site-deploy.
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:94)
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/NoGoalSpecifiedException
[Updated on: Mon, 07 August 2017 12:34] Report message to a moderator
Re: Creating new Scout project [message #1770083 is a reply to message #1770001] |
Tue, 08 August 2017 08:38 |
at the end I solved my problem in the following way.
I remove to my HD eclipse oxygen, I delete in my profile folder the .me2 folder and all reference of maven installed on my laptop.
At this point, I reinstall eclipse oxygen from installation package. At the end of the installation, I launch eclipse, I create a new workspace and at the end I create a new scout project and everything was created correctly.
I hope this help other person with the same problem
Current Time: Fri Apr 26 07:03:05 GMT 2024
Powered by FUDForum. Page generated in 0.02864 seconds
