My files are as such:
Component.xml
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0"
activate="activate"
configuration-policy="require"
deactivate="deactivate"
enabled="true"
immediate="true"
modified="updated"
name="org.eclipse.kura.example.configurable.ConfigurableExample">
<implementation class="org.eclipse.kura.example.configurable.ConfigurableExample"/>
<service>
<provide interface="org.eclipse.kura.example.configurable.ConfigurableExample"/>
</service>
<property name="service.pid" type="String" value="org.eclipse.kura.example.configurable.ConfigurableExample"/>
</scr:component>
org.eclipse.kura.example.configurable.ConfigurableExample.xml File
<MetaData xmlns="http://www.osgi.org/xmlns/metatype/v1.2.0" localization="en_us">
<OCD id="org.eclipse.kura.example.configurable.ConfigurableExample"
name="ConfigurableExample"
description="This is a sample metatype file for a simple configurable component">
<AD id="param1.string"
name="param1.string"
type="String"
cardinality="0"
required="true"
default="Some Text"
description="String configuration parameter"/>
<AD id="param2.float"
name="param2.float"
type="Float"
cardinality="0"
required="false"
default="20.5"
min="5.0"
max="40.0"
description="Float configuration parameter"/>
<AD id="param3.integer"
name="param3.integer"
type="Integer"
cardinality="0"
required="true"
default="2"
min="1"
description="Integer configuration parameter"/>
</OCD>
<Designate pid="org.eclipse.kura.example.configurable.ConfigurableExample">
<Object ocdref="org.eclipse.kura.example.configurable.ConfigurableExample"/>
</Designate>
</MetaData>
MANIFEST.MF File
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Configurable Componenet Example
Bundle-SymbolicName: org.eclipse.kura.example.configurable
Bundle-Version: 1.0.0.qualifier
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Import-Package: org.eclipse.kura.configuration;version="1.1.2",
org.osgi.service.component;version="1.2.0",
org.slf4j;version="1.7.21"
Service-Component: OSGI-INF/component.xml
build.properties File
output.. = bin/
bin.includes = META-INF/,\
OSGI-INF/
source.. = src/
additional.bundles = org.eclipse.osgi.services,\
slf4j.api,\
org.eclipse.kura.api
kura.log File after installation of Bundle
2017-08-03 13:02:24,749 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - Bundle org.eclipse.kura.configurable.ConfigurableExample has started!
2017-08-03 13:02:24,762 [mToolkit Worker #0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.example.configurable.ConfigurableExample ...
2017-08-03 13:02:24,777 [mToolkit Worker #0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.example.configurable.ConfigurableExample
2017-08-03 13:02:24,779 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - objectClass = [Ljava.lang.String;@124db3f of type class [Ljava.lang.String;
2017-08-03 13:02:24,780 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - param1.string = Some Text of type class java.lang.String
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - kura.service.pid = org.eclipse.kura.example.configurable.ConfigurableExample of type class java.lang.String
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - service.pid = org.eclipse.kura.example.configurable.ConfigurableExample of type class java.lang.String
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - param3.integer = 2 of type class java.lang.Integer
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - component.name = org.eclipse.kura.example.configurable.ConfigurableExample of type class java.lang.String
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - param2.float = 20.5 of type class java.lang.Float
2017-08-03 13:02:24,781 [Component Resolve Thread (Bundle 7)] INFO o.e.k.e.c.ConfigurableExample - New property - component.id = 43 of type class java.lang.Long
OSGi "ls" command output
osgi> ls
All Components:
ID State Component Name Located in bundle
1 Active org.eclipse.equinox.event org.eclipse.equinox.event(bid=8)
2 Active org.eclipse.kura.data.DataService org.eclipse.kura.core(bid=53)
3 Active org.eclipse.kura.db.DbService org.eclipse.kura.core(bid=53)
4 Active org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport org.eclipse.kura.core(bid=53)
5 Active org.eclipse.kura.ssl.SslManagerService org.eclipse.kura.core(bid=53)
6 Active org.eclipse.kura.system.SystemService org.eclipse.kura.core(bid=53)
7 Active org.eclipse.kura.system.SystemAdminService org.eclipse.kura.core(bid=53)
8 Active org.eclipse.kura.certificate.CertificatesService org.eclipse.kura.core.certificates(bid=54)
9 Active org.eclipse.kura.cloud.CloudService org.eclipse.kura.core.cloud(bid=55)
10 Registered org.eclipse.kura.cloud.CloudCallService org.eclipse.kura.core.cloud(bid=55)
11 Active org.eclipse.kura.core.cloud.factory.DefaultCloudServiceFactory org.eclipse.kura.core.cloud(bid=55)
12 Active org.eclipse.kura.cloud.app.command.CommandCloudApp org.eclipse.kura.core.cloud(bid=55)
13 Active org.eclipse.kura.core.comm.CommConnectionFactory org.eclipse.kura.core.comm(bid=56)
14 Active org.eclipse.kura.core.configuration.CloudConfigurationHandler org.eclipse.kura.core.configuration(bid=57)
15 Active org.eclipse.kura.configuration.ConfigurationService org.eclipse.kura.core.configuration(bid=57)
16 Active org.eclipse.kura.crypto.CryptoService org.eclipse.kura.core.crypto(bid=58)
17 Active org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 org.eclipse.kura.core.deployment(bid=59)
18 Active org.eclipse.kura.log.LoggerService org.eclipse.kura.core.log(bid=60)
19 Active org.eclipse.kura.status.CloudConnectionStatusService org.eclipse.kura.core.status(bid=62)
20 Active org.eclipse.kura.deployment.agent org.eclipse.kura.deployment.agent(bid=63)
21 Active org.eclipse.kura.clock.ClockService org.eclipse.kura.linux.clock(bid=64)
22 Registered org.eclipse.kura.command.CommandService org.eclipse.kura.linux.command(bid=65)
23 Active org.eclipse.kura.position.PositionService org.eclipse.kura.linux.position(bid=66)
24 Active org.eclipse.kura.usb.UsbService org.eclipse.kura.linux.usb(bid=68)
25 Active org.eclipse.kura.bluetooth.BluetoothService org.eclipse.kura.linux.bluetooth(bid=69)
26 Active org.eclipse.kura.watchdog.WatchdogService org.eclipse.kura.linux.watchdog(bid=70)
27 Active org.eclipse.kura.camel.KuraCloudComponentResolver org.eclipse.kura.camel(bid=76)
28 Unsatisfied org.eclipse.kura.camel.cloud.factory.CamelFactory org.eclipse.kura.camel.cloud.factory(bid=77)
29 Active org.eclipse.kura.camel.cloud.factory.CamelCloudServiceFactory org.eclipse.kura.camel.cloud.factory(bid=77)
30 Active org.eclipse.kura.camel.xml.XmlRouterComponent org.eclipse.kura.camel.xml(bid=78)
31 Unsatisfied org.eclipse.kura.asset org.eclipse.kura.asset.provider(bid=79)
32 Active org.eclipse.kura.asset.cloudlet org.eclipse.kura.asset.cloudlet.provider(bid=80)
33 Active org.eclipse.kura.asset.AssetService org.eclipse.kura.asset.helper.provider(bid=81)
34 Active org.eclipse.kura.driver.DriverService org.eclipse.kura.driver.helper.provider(bid=82)
35 Unsatisfied org.eclipse.kura.wire.CloudPublisher org.eclipse.kura.wire.component.provider(bid=86)
36 Unsatisfied org.eclipse.kura.wire.CloudSubscriber org.eclipse.kura.wire.component.provider(bid=86)
37 Unsatisfied org.eclipse.kura.wire.DbWireRecordFilter org.eclipse.kura.wire.component.provider(bid=86)
38 Unsatisfied org.eclipse.kura.wire.DbWireRecordStore org.eclipse.kura.wire.component.provider(bid=86)
39 Unsatisfied org.eclipse.kura.wire.Fifo org.eclipse.kura.wire.component.provider(bid=86)
40 Unsatisfied org.eclipse.kura.wire.Logger org.eclipse.kura.wire.component.provider(bid=86)
41 Unsatisfied org.eclipse.kura.wire.RegexFilter org.eclipse.kura.wire.component.provider(bid=86)
42 Unsatisfied org.eclipse.kura.wire.Timer org.eclipse.kura.wire.component.provider(bid=86)
43 Unsatisfied org.eclipse.kura.wire.WireAsset org.eclipse.kura.wire.component.provider(bid=86)
44 Active org.eclipse.kura.wire.WireHelperService org.eclipse.kura.wire.helper.provider(bid=87)
45 Registered org.eclipse.kura.wire.WireServiceCommand org.eclipse.kura.wire.provider(bid=88)
46 Active org.eclipse.kura.wire.WireService org.eclipse.kura.wire.provider(bid=88)
47 Active org.eclipse.kura.web.Console org.eclipse.kura.web2(bid=90)
48 Active org.eclipse.kura.gpio.GPIOService org.eclipse.kura.linux.gpio(bid=91)
49 Active org.eclipse.kura.emulator.Emulator org.eclipse.kura.emulator(bid=92)
50 Active org.eclipse.kura.net.NetworkService org.eclipse.kura.emulator.net(bid=93)
51 Active org.eclipse.kura.example.configurable.ConfigurableExample org.eclipse.kura.example.configurable(bid=95)
52 Active org.eclipse.kura.example.subscriber.Subscriber org.eclipse.kura.example.subscriber(bid=96)
