Eclipse Oxygen hangs [message #1769740] |
Thu, 03 August 2017 05:42 |
Reggie K Messages: 2 Registered: August 2017 |
Eclipse Oxygen javaEE with sts, checkstyle, lombok, flowable plugins hangs, and needs to be killed to work again.
Attaching the log with the freezes:
!ENTRY org.eclipse.ui.monitoring 4 0 2017-08-03 08:40:20.893
!MESSAGE UI freeze of 13s at 08:40:07.843
!SUBENTRY 1 org.eclipse.ui.monitoring 1 0 2017-08-03 08:40:20.893
!MESSAGE Sample at 08:40:13.303 (+5.460s)
Thread 'main' tid=1 (BLOCKED)
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.JobManager.setPriority(JobManager.java:1320)
at org.eclipse.core.internal.jobs.InternalJob.setPriority(InternalJob.java:428)
at org.eclipse.core.runtime.jobs.Job.setPriority(Job.java:690)
at org.eclipse.jdt.internal.ui.viewsupport.SelectionListenerWithASTManager$PartListenerGroup.firePostSelectionChanged(SelectionListenerWithASTManager.java:162)
at org.eclipse.jdt.internal.ui.viewsupport.SelectionListenerWithASTManager$PartListenerGroup$2.selectionChanged(SelectionListenerWithASTManager.java:95)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.notifyListeners(SelectionService.java:239)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.notifyListeners(SelectionService.java:174)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:213)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:250)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:247)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:755)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:680)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:95)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.lambda$0(ContributedPartRenderer.java:60)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$$Lambda$230/1989656096.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1542)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2467)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4887)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1657)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2199)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5191)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2555)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:88)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4941)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2454)
at org.eclipse.swt.internal.BidiUtil.windowProc(BidiUtil.java:701)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3152)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3812)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench$$Lambda$65/326190931.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!SUBENTRY 2 org.eclipse.ui.monitoring 1 0 2017-08-03 08:40:20.893
!MESSAGE Thread 'Worker-29' tid=201 (BLOCKED)
Waiting for: java.lang.Object@4b9c34c2 lock owner='Worker-8' tid=43
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.JobManager.nextJob(JobManager.java:1090)
at org.eclipse.core.internal.jobs.JobManager.startJob(JobManager.java:1603)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:221)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:52)
!MESSAGE Thread 'Worker-28' tid=200 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-27' tid=199 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-26' tid=198 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-25' tid=197 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread '825937134@qtp-1328839409-1 - Acceptor0 SocketConnector@127.0.0.1:51235' tid=63 (RUNNABLE)
!STACK 0
Stack Trace
at java.net.DualStackPlainSocketImpl.accept0(Native Method)
at java.net.DualStackPlainSocketImpl.socketAccept(Unknown Source)
at java.net.AbstractPlainSocketImpl.accept(Unknown Source)
at java.net.PlainSocketImpl.accept(Unknown Source)
at java.net.ServerSocket.implAccept(Unknown Source)
at java.net.ServerSocket.accept(Unknown Source)
at org.mortbay.jetty.bio.SocketConnector.accept(SocketConnector.java:99)
at org.mortbay.jetty.AbstractConnector$Acceptor.run(AbstractConnector.java:707)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
!MESSAGE Thread '1563809355@qtp-1328839409-0' tid=62 (TIMED_WAITING)
Waiting for: org.mortbay.thread.QueuedThreadPool$PoolThread@5d35d64b
!STACK 0
Stack Trace
at java.lang.Object.wait(Native Method)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:626)
!MESSAGE Thread 'YJP-Plugin-RequestListener' tid=60 (RUNNABLE)
!STACK 0
Stack Trace
at com.yourkit.c.l$1.run(a:18)
!MESSAGE Thread 'Worker-23' tid=58 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-22' tid=57 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-21' tid=56 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-19' tid=54 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-16' tid=51 (BLOCKED)
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.JobManager.endJob(JobManager.java:677)
at org.eclipse.core.internal.jobs.WorkerPool.endJob(WorkerPool.java:105)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!MESSAGE Thread 'Worker-15' tid=50 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-14' tid=49 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-13' tid=48 (TIMED_WAITING)
!STACK 0
Stack Trace
at java.lang.Thread.sleep(Native Method)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:289)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
!MESSAGE Thread 'Worker-12' tid=47 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-11' tid=46 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-10' tid=45 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-9' tid=44 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-8' tid=43 (RUNNABLE)
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.InternalJob.addLast(InternalJob.java:172)
at org.eclipse.core.internal.jobs.JobManager.nextJob(JobManager.java:1117)
!MESSAGE Thread 'Worker-7' tid=42 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-5' tid=40 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-4' tid=39 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-3' tid=38 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-2' tid=37 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'org.eclipse.jdt.internal.ui.text.JavaReconciler' tid=33 (TIMED_WAITING)
Waiting for: org.eclipse.jface.text.reconciler.DirtyRegionQueue@051488b2
!STACK 0
Stack Trace
at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:180)
!MESSAGE Thread 'Java indexing' tid=31 (WAITING)
Waiting for: org.eclipse.jdt.internal.core.search.indexing.IndexManager@72f63f05
!STACK 0
Stack Trace
at java.lang.Object.wait(Unknown Source)
at org.eclipse.jdt.internal.core.search.processing.JobManager.run(JobManager.java:373)
!MESSAGE Thread 'Thread-2' tid=26 (WAITING)
Waiting for: java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f0a56a4
!STACK 0
Stack Trace
at sun.misc.Unsafe.park(Native Method)
at java.util.concurrent.locks.LockSupport.park(Unknown Source)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source)
at java.util.concurrent.ArrayBlockingQueue.take(Unknown Source)
at org.eclipse.equinox.weaving.internal.caching.CacheWriter$1.run(CacheWriter.java:47)
!MESSAGE Thread 'Worker-1' tid=25 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'Worker-0' tid=23 (BLOCKED)
!STACK 0
Stack Trace
!MESSAGE Thread 'EMF Reference Cleaner' tid=22 (WAITING)
Waiting for: java.lang.ref.ReferenceQueue$Lock@622da293
!STACK 0
Stack Trace
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
!MESSAGE Thread 'Worker-JM' tid=21 (WAITING)
Waiting for: java.util.ArrayList@21e0a7c4
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:59)
!MESSAGE Thread 'SCR Component Actor' tid=20 (WAITING)
Waiting for: java.util.LinkedList@5ca26a2a
!STACK 0
Stack Trace
at org.apache.felix.scr.impl.ComponentActorThread.run(ComponentActorThread.java:80)
!MESSAGE Thread 'Worker-30' tid=202 (BLOCKED)
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:214)
!MESSAGE Sample at 08:40:15.973 (+2.670s)
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
at org.eclipse.core.internal.jobs.JobManager.findBlockingJob(JobManager.java:732)
at org.eclipse.core.internal.jobs.JobManager.nextJob(JobManager.java:1107)
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!STACK 0
Stack Trace
!MESSAGE Sample at 08:40:18.633 (+2.660s)
!STACK 0
Stack Trace
FUDForum. Page generated in 0.08331 seconds
