Re: Not able to evaluate sort, grouping, filter or binding expression. A data field that is used in [message #1772744 is a reply to message #1769114] |
Thu, 14 September 2017 15:25 |
Shivkant G Messages: 2 Registered: July 2017 |
Shivkant G wrote on Wed, 26 July 2017 15:35Hi Guys,
Im getting below error while running reports.
I have flat file WC_Library_WhatDoesItDo.csv that returns 0 results and report fails to open.
Visibility property is added at all the possible places.
Still getting error while running report. For csv returning results more than 0, it works fine without any issues.
Birt is upgraded to 4.4.2
Below files are customized in deployment directory:
1. ReportIndex.rptdesign
2. ToolbarFragment.jsp
3. WC_Library_WhatDoesItDo.csv
4. WC_Library_WhatDoesItDo_Master.rptlibrary
Getting below error:
2017-07-26T11:27:40,821:tainer : 2 [DEBUG] AxisFault:
org.apache.axis.AxisFault: ; nested exception is:
org.eclipse.birt.report.engine.api.EngineException: Not able to evaluate sort, grouping, filter or binding expression. A data field that is used in the expression does not exist in the dataset.
Invalid field name: Report_MenuName.
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101) ~[axis-1.4.jar:?]
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777) ~[viewservlets.jar:?]
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:755) ~[viewservlets.jar:?]
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:797) ~[viewservlets.jar:?]
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:90) ~[viewservlets.jar:?]
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58) ~[viewservlets.jar:?]
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:118) ~[viewservlets.jar:?]
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:103) ~[viewservlets.jar:?]
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90) ~[viewservlets.jar:?]
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47) ~[viewservlets.jar:?]
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143) ~[viewservlets.jar:?]
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87) ~[viewservlets.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.7.0]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95) ~[?:1.7.0]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56) ~[?:1.7.0]
at java.lang.reflect.Method.invoke(Method.java:620) ~[?:2.6 (10-05-2016)]
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112) ~[viewservlets.jar:?]
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66) ~[viewservlets.jar:?]
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397) ~[axis-1.4.jar:?]
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186) ~[axis-1.4.jar:?]
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323) ~[axis-1.4.jar:?]
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32) ~[axis-1.4.jar:?]
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) ~[axis-1.4.jar:?]
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) ~[axis-1.4.jar:?]
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454) ~[axis-1.4.jar:?]
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281) ~[axis-1.4.jar:?]
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699) [axis-1.4.jar:?]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265) [viewservlets.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595) [javax.j2ee.servlet.jar:?]
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327) [axis-1.4.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668) [javax.j2ee.servlet.jar:?]
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122) [viewservlets.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:136) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:79) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:967) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1107) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.dispatch(WebAppRequestDispatcher.java:1389) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forward(WebAppRequestDispatcher.java:195) [com.ibm.ws.webcontainer.jar:?]
at org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1063) [struts-1.2.7.jar:1.2.7]
at org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:386) [struts-1.2.7.jar:1.2.7]
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:229) [struts-1.2.7.jar:1.2.7]
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1194) [struts-1.2.7.jar:1.2.7]
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432) [struts-1.2.7.jar:1.2.7]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:97) [com.ibm.ws.webcontainer.jar:?]
at com.carreker.reportviewer.common.CrossSiteScriptBlockFilter.doFilter(CrossSiteScriptBlockFilter.java:81) [classes/:?]
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:195) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:91) [com.ibm.ws.webcontainer.jar:?]
at org.owasp.csrfguard.http.FilterChainWrapper.doFilter(FilterChainWrapper.java:42) [Owasp.csrfGuard-mod-6.4.2.jar:?]
at org.owasp.csrfguard.CsrfGuardFilter.doFilter(CsrfGuardFilter.java:158) [Owasp.csrfGuard-mod-6.4.2.jar:?]
at com.carreker.reportviewer.common.RequestFilter.doFilter(RequestFilter.java:100) [classes/:?]
at com.carreker.reportviewer.action.ApplicationFilter.doFilter(ApplicationFilter.java:48) [classes/:?]
at com.carreker.reportviewer.common.ExceptionFilter.doFilter(ExceptionFilter.java:52) [classes/:?]
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:949) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200) [com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) [com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) [com.ibm.ws.runtime.jar:?]
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892) [com.ibm.ws.runtime.jar:?]
Caused by: org.eclipse.birt.report.engine.api.EngineException: Not able to evaluate sort, grouping, filter or binding expression. A data field that is used in the expression does not exist in the dataset.
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1245) ~[?:?]
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1224) ~[?:?]
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96) ~[?:?]
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62) ~[?:?]
Appreciate your help!
Shivkant G
FUDForum. Page generated in 0.02959 seconds
