Home » Eclipse Projects » EclipseLink » DDL & MySQL & Primary Key
DDL & MySQL & Primary Key [message #1769021] Tue, 25 July 2017 14:32 Go to next message
I am trying to use DDL to generate my database automatically BUT this case causes an error :
  • @Id on a String
  • MySQL database
It generates this code with an "AUTO_INCREMENT" on a "VARCHAR" :
  • CREATE TABLE t_systeme (PARAM VARCHAR(255) AUTO_INCREMENT NOT NULL, DESCRIPTION VARCHAR(255), VALEUR VARCHAR(255), REF_SOCIETE INTEGER, PRIMARY KEY (PARAM))
Why ? How to fix this ?
Thanks in advance.
Re: DDL & MySQL & Primary Key [message #1769112 is a reply to message #1769021] Wed, 26 July 2017 11:29 Go to previous message
Not sure what you are looking for. Why are you using ID generation on a string value, should it not be an Integer type in your object?
Your Id likely has the @GeneratedValue(strategy=GenerationType.IDENTITY) annotation that you either need to remove and set the values yourself, or switch it to a numeric like Integer.
[Updated on: Wed, 26 July 2017 11:43] by Moderator
Previous Topic:Persist with secondaryTable from non PK field
Next Topic:Setting up cache coordination with Payara
Current Time: Sun Oct 26 23:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.05676 seconds
