[Resolved] Sirius Open Dialog [message #1768980] |
Tue, 25 July 2017 11:57 |
Hi there,
I am currently trying to implement an Open Dialogue in container creation.
I first create an Instance (for the container) that I need, then I add an Open Dialogue.
I can manage the Cancel button (to simply remove the instance created) and the OK button (currently it does nothing).
I then add some "text" widget to the dialogue.
My question is, how you do extract the input in the text widget to set the properties of the instance with the inputs?
Will
Research Associate
Department of Computer Science
University of York
[Updated on: Mon, 31 July 2017 12:39] Report message to a moderator
Re: Sirius Open Dialog [message #1768986 is a reply to message #1768985] |
Tue, 25 July 2017 12:53 |
Hi Steve,
Thanks, so if I create the instance in the first place, how do you edit the properties using text widgets?
Will
Research Associate
University of York
Re: Sirius Open Dialog [message #1768992 is a reply to message #1768991] |
Tue, 25 July 2017 13:51 |
Hi Steve,
I am wonder how you'd access the input in the dialog, suppose i have a text field which asks the user for the "name" property of the instance. How do I access the input that the user enters?
Will
Research Associate
University of York
Re: Sirius Open Dialog [message #1769179 is a reply to message #1769163] |
Thu, 27 July 2017 09:54 |
Hi Steve,
I am afraid you are not answering my question.
So I create an instance and then I open a dialog. With the dialog I create a text widget: name. This text widget should get the user input and set the name of the instance to the user input.
I know how to access the instance created. My question is, how do you access the user input?
Hope this is clear to you.
Will
Research Associate
University of York
Re: Sirius Open Dialog [message #1769248 is a reply to message #1769179] |
Fri, 28 July 2017 08:52 |
Hi William,
In a Sirius tool, we are always working with the variables accessible starting with self, the current semantic element. In your situation, you just need to create a new instance and then open a dialog containing a page and a group. Once you are on the group, you can use a text widget to edit the value of the property name of the newly created instance.
For a more detailed version, have a look at those screenshots and the final result in video
Stephane Begaudeau, Obeo
Re: Sirius Open Dialog [message #1769397 is a reply to message #1769248] |
Mon, 31 July 2017 10:27 |
Hi Stephane,
Thanks very much for your help! I have managed to get the open dialog up and running.
Many thanks again.
Will
Research Associate
University of York
FUDForum. Page generated in 0.03310 seconds
