Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Validation & OCL
Validation & OCL [message #33700] Tue, 09 May 2006 04:25 Go to next message
Originally posted by: asha_rajbhoj.yahoo.com
One Constraint from UML 1.3 spec : "No Attributes may have the same name
within a Classifier."
Various model update scenario could be adding attribute for classifier ,
modifying attribute name , deletion of attribute.
When I specify constraint as follows it can address adding attribute
scenario
<constraint lang="OCL" ...>
<target class="Classifier">
<event name="Set">
<feature name="attribute" />
</event>
</target>
self.feature->select ( a | a.oclIsKindOf (Attribute) )->forAll
( p, q |
p.name = q.name implies p = q )
</constraint>
But it does not address modifying of attribute name. How to specify such
indirect event for the target classes using validation framework?
Thanks and Regards,
Asha.
Re: Validation & OCL [message #33738 is a reply to message #33700] Tue, 09 May 2006 11:37 Go to previous messageGo to next message
Hello Asha,
It looks like your OCL constraints are live.
Is it possible for you to write a separate constraint that tests the
other event (please excuse my OCL) something like this:
<target class="Attribute">
<event name="Set">
<feature name="name" /> </event>
</target>
self.classifier.feature->select ( a | a.oclIsKindOf
(Attribute))->forAll( p | p.name = self.name implies p = self )
</constraint>
Chris McGee
asha wrote:
> name within a Classifier."
> scenario
> <event name="Set">
> <feature name="attribute" /> </event>
> </target>
> ( p, q |
> </constraint>
> Thanks and Regards,
> Asha.
Re: Validation & OCL [message #33771 is a reply to message #33738] Wed, 10 May 2006 00:17 Go to previous messageGo to next message
Originally posted by: asha.rajbhoj.yahoo.com
Hi Chris,
Yes , we can write multiple OCL for such indirect events.
But, semantically constraint is only for Class and not for Attribute. But
we end up in writing constraint even for Attribute to implement Class
level constraint for handling indirect event.
Does Validation framework has some feature to avoid writing such multiple
OCL for indirect event?
Thanks and Regards,
Asha.
Re: Validation & OCL [message #33839 is a reply to message #33771] Wed, 10 May 2006 11:24 Go to previous message
Hi Asha,
The way that regular Java live constraints handle this issue is to write
their code to handle the different possible events that could trigger
the constraint as different cases. Unfortunately, this information isn't
provided to OCL constraints.
Is there any way to check the type of the 'self' object and perform
different checks based on the type in the OCL language? I notice that in
your case the two events are coming from different classes so this might
be an acceptable way of differentiating.
Chris
Asha wrote:
> Hi Chris,
> But we end up in writing constraint even for Attribute to implement
> Class level constraint for handling indirect event.
> multiple OCL for indirect event?
> Thanks and Regards,
> Asha.
Re: Validation & OCL [message #577214 is a reply to message #33700] Tue, 09 May 2006 11:37 Go to previous message
Hello Asha,
<event name="Set">
</target>
</constraint>
Chris McGee
asha wrote:
> scenario
> <event name="Set">
> </target>
> ( p, q |
> </constraint>
> Thanks and Regards,
> Asha.
Re: Validation & OCL [message #577238 is a reply to message #33738] Wed, 10 May 2006 00:17 Go to previous message
Hi Chris,
Thanks and Regards,
Asha.
Re: Validation & OCL [message #577309 is a reply to message #33771] Wed, 10 May 2006 11:24 Go to previous message
Hi Asha,
Chris
Asha wrote:
> Hi Chris,
> Thanks and Regards,
> Asha.
Previous Topic:Validation & OCL
Next Topic:OclInvalid as method argument
Current Time: Mon May 19 07:17:33 EDT 2025
Powered by FUDForum. Page generated in 0.07495 seconds
