Re: Check model instances when run-time environment is loading [message #1768506 is a reply to message #1768491] |
Wed, 19 July 2017 14:41 |
Ed Merks Messages: 33142 Registered: July 2009 |
The question remains, where is all this being loaded? Presumably all in some resource set, that you create? You can listen to a resource set loading resources. You can also use an EContentAdapter to add a single adapter a resource set, all resources it contains, and to all objects in those resources. It updates (attached itself) automatically. Perhaps something like that would help. In the end though, I imagine your loading something into a resource set and what to do that checks after that's been done.
Ed Merks
FUDForum. Page generated in 0.03436 seconds
