Home » Eclipse Projects » Oomph » Oomph root setup and start issues on Linux Mint 18 / Ubuntu 16 LTE
Oomph root setup and start issues on Linux Mint 18 / Ubuntu 16 LTE [message #1766346] Tue, 20 June 2017 12:19 Go to next message
Lars Haendler is currently offline Lars HaendlerFriend
I decided to go from Eclipse Mars to Neo and set up a test VM. I downloaded the eclipse-inst-linux64.tar.gz, extracted it and tried to run ./eclipse-inst from my default user. I ended up with this error message:
java.lang.RuntimeException: Error initializing storage.
java.io.FileNotFoundException: /home/hlars/Downloads/eclipse-installer/configuration/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
I sudo'ed the installer and everything went along just fine. I chose to install Neon - like I did with Mars - in my user home directory. In this case: /home/hlars/jee-neon/
Starting Eclipse with my default user returns this error:
/root/.p2/pool/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740: cannot open shared object file: Permission denied
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
Starting Eclipse with sudo works just fine. But I do not want to start Eclipse as root user. Did I do something wrong with the install?
Re: Oomph root setup and start issues on Linux Mint 18 / Ubuntu 16 LTE [message #1766385 is a reply to message #1766346] Tue, 20 June 2017 20:21 Go to previous messageGo to next message
Does your regular user account not have write access to /home/hlars/Downloads/eclipse-installer/configuration/org.eclipse.osgi/.manager ? Where did you locate the bundle pool. You can choose a different location via the menu. In general I expect all the defaults when you run the first time as a user would be using locations in your user home folder.
Ed Merks
Re: Oomph root setup and start issues on Linux Mint 18 / Ubuntu 16 LTE [message #1766398 is a reply to message #1766385] Wed, 21 June 2017 05:38 Go to previous message
I got it figured out. I tried two different VMs with Mint 18.1 but the installer always halts with an error no matter what I do. The trick was just to restart the installation. Once it runs a second time everything is fine.
The mess I created by sudo'ing the installation is on me. I should have known better.
Previous Topic:Oomph target platform setup
Next Topic:Eclipse neon 64 bit installation failing
Current Time: Fri Apr 26 10:02:08 GMT 2024
Powered by FUDForum. Page generated in 0.04253 seconds
