Click 'Help->Help Contents', Eclipse is crashed in Linux [message #1765321] |
Thu, 08 June 2017 12:26 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nicholas Kong![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=nicholas_kong%40163.com) Messages: 59 Registered: July 2016 Location: China |
Member |
To whom it may concern,
When I click 'Help->Help Contents' menu on Linux (Neon 4.6.3). The Eclipse platform always no responding and Crash.
So does there have any one know is it a bug or how to fix it?
Thank you.
Eclipse Version
Eclipse Modeling Tools
Version: Neon.3 Release (4.6.3)
Build id: 20170314-1500
Linux Version
Linux version 2.6.32-431.el6.x86_64 (mockbuild@x86-023.build.eng.bos.redhat.com) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC) ) #1 SMP Sun Nov 10 22:19:54 EST 2013
Java Version
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
==================================Info================================
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fdcc80bb030, pid=5134, tid=0x00007fddde5be700
# JRE version: Java(TM) SE Runtime Environment (8.0_131-b11) (build 1.8.0_131-b11)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.131-b11 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C 0x00007fdcc80bb030
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
[Updated on: Wed, 21 June 2017 01:34] Report message to a moderator
Re: Click 'Help->Help Contents', Eclipse is crashed in Linux [message #1766003 is a reply to message #1765321] |
Wed, 14 June 2017 18:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Could you try getting a code dump.
My guess is that you're encountering issues loading the embedded web browser. Can you try opening the internal web browser (Quick Access > "Web Browser" and select the "Internal Web Browser")? If that crashes too, there are some details in the SWT FAQ on diagnosing and solving the issues.
That said, Help > Help Contents for me actually opens a web browser.
Brian.
Re: Click 'Help->Help Contents', Eclipse is crashed in Linux [message #1766879 is a reply to message #1766837] |
Wed, 28 June 2017 13:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
And I follow your step: (Quick Access > "Web Browser" and select the "Internal Web Browser")
If I do not set the web location (defaule:empty page), the browser works will.
If I point the location to the Help Content Part. such as: http://127.0.0.1:39373/help/nav/15,
the Platform also crash.
Can you try using a different URL instead of your local help on localhost, like www.eclipse.org? Does that crash? That will help isolate whether it's the SWT Browser crashing (my suspicion) or the Help system crashing (seems very unlikely to crash the JVM).
From the .logs it looks like SWT Browser crashing:
Stack: [0x00007f5d7cd6a000,0x00007f5d7ce6b000], sp=0x00007f5d7ce677b0, free space=1013k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x00007f5c7c928000
C [libwebkit-1.0.so.2+0xa8a2c0]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J 5706 org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ)Z (0 bytes) @ 0x00007f5d691007c4 [0x00007f5d69100780+0x44]
J 10068 C2 org.eclipse.swt.widgets.Display.readAndDispatch()Z (71 bytes) @ 0x00007f5d6a97c154 [0x00007f5d6a97bea0+0x2b4]
j org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run()V+530
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
I'm not sure what version of version of RHEL you're using. You may well have buggy versions of GTK3 libraries. Perhaps you could try running with SWT_GTK3=0 in your environment (or launch Eclipse with "--launcher.GTK_version 2") and see if that helps.
Brian.
FUDForum. Page generated in 0.03509 seconds
