Home » Archived » EPF » Re-use Rich Text Editor component on Mac?
Re: Re-use Rich Text Editor component on Mac? [message #42934 is a reply to message #34713] |
Mon, 08 October 2007 20:37 |
Originally posted by: eclipse6.rizzoweb.com
Phillip Beauvoir wrote:
> I've extrapolated the following bundles that are needed for the RTE
> (version 1.2) to work in a RCP application:
> org.eclipse.epf.common
> org.eclipse.epf.richtext
> org.eclipse.epf.ui
> I have a RichTextEditor class instantiated in an Editor View together
> with a populated RichTextToolBar. This all works fine on Windows XP and
> Ubuntu 7 (apart from a bug I noticed on the Toolbar layout).
Can you share the details of how you implemented RichTextEditor in a
non-EPF application? I'm in the process of doing so and would like to
hear any lessons that were learned by someone who has already been down
this path.
Eric
Re: Re-use Rich Text Editor component on Mac? [message #42965 is a reply to message #34713] |
> org.eclipse.epf.ui
this path.
Eric
Re: Re-use Rich Text Editor component on Mac? [message #42996 is a reply to message #42965] |
Mon, 08 October 2007 20:53 |
h1055071 Messages: 335 Registered: July 2009 |
>> org.eclipse.epf.ui
>> and Ubuntu 7 (apart from a bug I noticed on the Toolbar layout).
> this path.
> Eric
Hi, yes:
For a start it only works on Windows and Linux, the Mac is going to need
some Safari-specific voodoo added to the rte.js and rendering files in
the rte folder.
The plug-in I put together is here in CVS:
Host: tencompetence.cvs.sourceforge.net
Path: /cvsroot/tencompetence
Module: rte/org.eclipse.epf.richtext
I then instantiate a RTE control thus:
class RTE
extends RichTextEditor
public RTE(Composite parent, int style, IEditorSite editorSite,
String basePath) {
super(parent, style, editorSite, basePath);
public RTE(Composite parent, int style, IEditorSite editorSite) {
super(parent, style, editorSite);
public void fillToolBar(IRichTextToolBar toolBar) {
toolBar.addAction(new FontStyleAction(this));
toolBar.addAction(new FontNameAction(this));
toolBar.addAction(new FontSizeAction(this));
toolBar.addSeparator();
toolBar.addAction(new CutAction(this));
toolBar.addAction(new CopyAction(this));
toolBar.addAction(new PasteAction(this));
toolBar.addAction(new ClearContentAction(this));
toolBar.addAction(new BoldAction(this));
toolBar.addAction(new ItalicAction(this));
toolBar.addAction(new UnderlineAction(this));
toolBar.addAction(new SubscriptAction(this));
toolBar.addAction(new SuperscriptAction(this));
toolBar.addAction(new TidyActionGroup(this));
toolBar.addAction(new AddOrderedListAction(this));
toolBar.addAction(new AddUnorderedListAction(this));
toolBar.addAction(new OutdentAction(this));
toolBar.addAction(new IndentAction(this));
toolBar.addAction(new FindReplaceAction(this) {
public void execute(IRichText richText) {
richText.getFindReplaceAction().execute(richText);
toolBar.addAction(new AddLinkAction(this));
toolBar.addAction(new AddImageAction(this));
toolBar.addAction(new AddTableAction(this));
And then add it to an EditorPart.
PB
Re: Re-use Rich Text Editor component on Mac? [message #46307 is a reply to message #42996] |
Wed, 05 December 2007 09:00 |
>>> org.eclipse.epf.ui
>> down this path.
>> Thanks,
>> Eric
> Hi, yes:
> the rte folder.
> class RTE
> String basePath) {
> @Override
> @Override
> PB
Hi all,
You may be interested to know that the RichTextEditor seems to work now
with the new the version of Safari (3.0).
I'm also doing an RCP application that reuses the RichTextEditor. The
buttons now works in the wysiwyg tab.
Best regards
Yannick
Re: Re-use Rich Text Editor component on Mac? [message #46337 is a reply to message #46307] |
Wed, 05 December 2007 14:27 |
Originally posted by: eclipse-news.rizzoweb.com
Yannick Lizzi wrote:
> Hi all,
Yannick,
You might be interested in this Bug report which requests the RTE be
improved for consumability:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209373
Feel free to vote for it and/or add comments.
Eric
Re: Re-use Rich Text Editor component on Mac? [message #47888 is a reply to message #46307] |
Sun, 10 February 2008 01:04 |
Sung Ahn Kim Messages: 7 Registered: July 2009 |
Buttons work but the editor section fail to refresh its contents.
Also, save and close key binding doesn't work in the editor.
(Of cource, it works fine on Windows)
There can be alternative approach. Use firefox instead of Safari.
Rich text editor uses platform specific web browser instance.
new Borwser(parent, SWT.NONE)
now eclipse 3.3 support firefox everywhere.
new Browser(parent, SWT.MOZILLA)
Unfortunately, when I change its style, my eclipse app. crashes caused by
jni call (3.4M4) or unknow problem (3.3.1.1). SWT mozilla example works
fine ... If SWT fix this unstable behavior, we can use rich text without
pain.
Yes, that is only my hope. But, there is an alternative approach.
1) Support safari on mac
2) Or, support mozilla everywhere
Re: Re-use Rich Text Editor component on Mac? [message #584387 is a reply to message #42965] |
>> org.eclipse.epf.ui
> this path.
> Eric
Hi, yes:
the rte folder.
class RTE
String basePath) {
PB
Re: Re-use Rich Text Editor component on Mac? [message #585832 is a reply to message #42996] |
>>> org.eclipse.epf.ui
>> down this path.
>> Thanks,
>> Eric
> Hi, yes:
> the rte folder.
> class RTE
> String basePath) {
> @Override
> @Override
> PB
Hi all,
Best regards
Yannick
Re: Re-use Rich Text Editor component on Mac? [message #588395 is a reply to message #46307] |
pain.
Current Time: Thu Apr 25 12:42:56 GMT 2024
Powered by FUDForum. Page generated in 0.05720 seconds
