Re: How to debug an Oomph setup model? [message #1764895 is a reply to message #1764868] |
Sat, 03 June 2017 04:34 |
Ed Merks Messages: 33142 Registered: July 2009 |
Unfortunately the launchers tend to grow stale. Much of that is because, in my opinion, their design is rather poor. The point is that they might have explicit bundle versions specified so that if we resolve a newer version of the target platform, they don't resolve properly. Also, there are tricky things especially for the installer launch where we need to minimize the number of plugins launched, so we make it feature-based, but then certain important plugins from p2 and especially org.eclipse.equinox.ds are missing so they need to be specifically added resulting in this in the *.launch:<setAttribute key="additional_plugins">
<setEntry value="org.eclipse.equinox.ds:1.5.0.v20170307-1429:default:true"/>
<setEntry value="org.eclipse.equinox.p2.artifact.repository:1.1.500.v20160419-0834:default:true"/>
<setEntry value="org.eclipse.equinox.p2.console:1.0.500.v20170105-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.core:2.4.100.v20160419-0834:default:true"/>
<setEntry value="org.eclipse.equinox.p2.director.app:1.0.500.v20160419-0834:default:true"/>
<setEntry value="org.eclipse.equinox.p2.director:2.3.300.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.directorywatcher:1.1.100.v20150423-1455:default:true"/>
<setEntry value="org.eclipse.equinox.p2.discovery.compatibility:1.0.200.v20131211-1531:default:true"/>
<setEntry value="org.eclipse.equinox.p2.discovery:1.0.400.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.engine:2.5.0.v20170110-1705:default:true"/>
<setEntry value="org.eclipse.equinox.p2.extensionlocation:1.2.300.v20160419-0834:default:true"/>
<setEntry value="org.eclipse.equinox.p2.garbagecollector:1.0.300.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.jarprocessor:1.0.500.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.metadata.repository:1.2.300.v20170131-1152:default:true"/>
<setEntry value="org.eclipse.equinox.p2.metadata:2.3.100.v20170105-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.operations:2.4.200.v20160830-1950:default:true"/>
<setEntry value="org.eclipse.equinox.p2.publisher.eclipse:1.2.100.v20170131-1152:default:true"/>
<setEntry value="org.eclipse.equinox.p2.publisher:1.4.100.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.reconciler.dropins:1.1.400.v20160504-1450:default:true"/>
<setEntry value="org.eclipse.equinox.p2.repository.tools:2.1.300.v20170110-0218:default:true"/>
<setEntry value="org.eclipse.equinox.p2.repository:2.3.200.v20170208-2010:default:true"/>
<setEntry value="org.eclipse.equinox.p2.touchpoint.eclipse:2.1.400.v20160419-0834:default:true"/>
<setEntry value="org.eclipse.equinox.p2.touchpoint.natives:1.2.100.v20170109-2036:default:true"/>
<setEntry value="org.eclipse.equinox.p2.transport.ecf:1.1.300.v20161004-0244:default:true"/>
<setEntry value="org.eclipse.equinox.p2.updatesite:1.0.600.v20160504-1450:default:true"/>
</setAttribute>
So if any of those change, the launch is broken again.
So definitely in each case it's important to use the Plug-ins tab to validate the plugins and to add p2 and equinox.ds until the launchers are in reasonable shape. Even then, for the installer there will remain complaints about fragments from other platform architectures not working; another bug in PDE in my opinion, i.e., how can one create a launcher that works on all platforms with a target platform that resolves all platforms?
Also, while Oomph itself doesn't require Java 8, or even Java 7, the Eclipse platform itself does, so you need to provision the workspace with a 1.8 JRE, even though the Oomph source code doesn't need that. Otherwise you won't be able to launch the Eclipse platform. You're logs suggest you might not have done that.
Sorry for the hassle. We really should at leave update the launchers to be valid with the latest Oxygen target platform (on Windows)...
Ed Merks
FUDForum. Page generated in 0.03419 seconds
