Home » Modeling » ATL » problem with the iteration
problem with the iteration [message #1764570] Wed, 31 May 2017 06:52 Go to next message
In the following code, i want that the id takes in each iteration a number from the sequence 's', so as a result in my target model i obtain the id 1 then 2 if i had 2 source elements, 1,2,3 if i had 3 source elements etc...
 from...
to
split: ABC!Loc (
			id <- let s: Sequence(Integer) = Sequence{1, 2, 3, 4, 5} in
s->iterate(e; res : Integer = s->first() |( e).toString()),
the problem is, i always get the last element in my target model, my id are always 5 , there is no iteration on 's' to get the following ids: 1,2 for example.
please, how to make this happen.
regards
Re: problem with the iteration [message #1764643 is a reply to message #1764570] Thu, 01 June 2017 03:01 Go to previous message
Why don't you use allInstances() together size() methods?
For example:
from
s: ...........
to
split: ABC!Loc ( )
do{
split.id<- s.allInstances()->size().toString();
Previous Topic:synchronisation between counters in two separated matched rules
Next Topic:Lazy rule: problem with a counter
Current Time: Fri Nov 07 06:13:24 EST 2025
Powered by FUDForum. Page generated in 0.02717 seconds
