Home » Eclipse Projects » P2 » Wrong bundle loaded after update on macosx
Wrong bundle loaded after update on macosx [message #1763975] |
Tue, 23 May 2017 14:19 |
Guillaume Papon Messages: 13 Registered: August 2016 |
I have a problem with p2 updating on mac os x, i described it here for more context.
We use the standard UpdateService which is working correctly. The app loads new stuff from repository and put it in app/plugins directory, so we end up having in this directory both versions of each of our plugins (say versions 1 and 2).
On windows, when the app starts, it picks up the correct version of the plugins (version 2), but on mac, it keeps loading the wrong one (version 1). If i delete all v1 jars, it picks up the correct ones (v2 obviously) but if i then undelete them (so we now have back v1 and V2), it keeps taking v2.
I noticed a difference between windows and mac in the file configuration\org.eclipse.equinox.simpleconfigurator\bundles.info (which, correct me if i am wrong, seems to describe the jars to load)
On windows, when i do the update, this file contains only the new version of the jars, ex:
dp.fast.app,2.0.1,plugins/dp.fast.app_2.0.1.jar,4,false
dp.fast.app.update,2.0.1,plugins/dp.fast.app.update_2.0.1.jar,4,false
dp.fast.app.workbench,2.0.1,plugins/dp.fast.app.workbench_2.0.1.jar,4,false
dp.fast.connector,2.0.1,plugins/dp.fast.connector_2.0.1.jar,4,false
dp.fast.core,2.0.1,plugins/dp.fast.core_2.0.1.jar,4,false
dp.fast.core.fx,2.0.1,plugins/dp.fast.core.fx_2.0.1.jar,4,false
But on mac, it contains both the old and the new version:
dp.fast.app,2.0.0,plugins/dp.fast.app_2.0.0.jar,4,false
dp.fast.app.update,2.0.0,plugins/dp.fast.app.update_2.0.0.jar,4,false
dp.fast.app.workbench,2.0.0,plugins/dp.fast.app.workbench_2.0.0.jar,4,false
dp.fast.connector,2.0.0,plugins/dp.fast.connector_2.0.0.jar,4,false
dp.fast.core,2.0.0,plugins/dp.fast.core_2.0.0.jar,4,false
dp.fast.core.fx,2.0.0,plugins/dp.fast.core.fx_2.0.0.jar,4,false
I guess the problem lays here. If i remove the lines containing the old version, the app correctly loads the new bundle (obvioulsy).
So what can create these double lines ?
Current Time: Fri Apr 26 15:47:52 GMT 2024
Powered by FUDForum. Page generated in 0.22423 seconds
