problem when migrating from oracle11 to oracle12e [message #1763638] |
Thu, 18 May 2017 09:25 |
Avinash TS Messages: 3 Registered: May 2017 |
Hi ,
I have spent lot of time on fixing the above issue , still i don't have any clue .So i just want to make sure whether we can use Eclipselink jar to connect oracle 12 db or not .
I have tried various version of eclipselink. No use
it works fine with Oracle 11 and ojdbc14.jar
And now we are working on migrating to oracle12 and i tried using ojdbc 7 and ojdbc 6 jars.
Please find my project configurations below
1. Java 1.8
2. Spring 3.2.1 Realease
3. Ojdbc7.jar (am using it now )
with these configurations am gettinf below exception .please find it below
2017/05/18 09:13:58.299 [RMI TCP Connection(8)-10.197.6.152]: AUDIT- ERROR: Error while invoking a client call: saveOrUpdateItvApplicationAggregate. Error is: org.springframework.transaction.TransactionSystemException: Could not commit JPA transaction; nested exception is javax.persistence.RollbackException: java.lang.ClassCastException: org.apache.commons.dbcp.PoolableConnection cannot be cast to oracle.jdbc.OracleConnection
[Exception: org.springframework.transaction.TransactionSystemException: Could not commit JPA transaction; nested exception is javax.persistence.RollbackException: java.lang.ClassCastException: org.apache.commons.dbcp.PoolableConnection cannot be cast to oracle.jdbc.OracleConnection
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:522)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:755)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:724)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:387)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:120)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.adapter.AfterReturningAdviceInterceptor.invoke(AfterReturningAdviceInterceptor.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:161)
at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:91)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy67.saveOrUpdateItvApplicationAggregate(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.springframework.remoting.support.RemoteInvocationTraceInterceptor.invoke(RemoteInvocationTraceInterceptor.java:77)
at $Proxy69.saveOrUpdateItvApplicationAggregate(Unknown Source)
at org.springframework.remoting.support.RemoteInvocation.invoke(RemoteInvocation.java:205)
at org.springframework.remoting.support.DefaultRemoteInvocationExecutor.invoke(DefaultRemoteInvocationExecutor.java:38)
at org.springframework.remoting.support.RemoteInvocationBasedExporter.invoke(RemoteInvocationBasedExporter.java:78)
at org.springframework.remoting.rmi.RmiBasedExporter.invoke(RmiBasedExporter.java:73)
at com.cab.infra.highavailability.rmi.exporter.InfraRmiServiceExporter.invoke(InfraRmiServiceExporter.java:254)
at org.springframework.remoting.rmi.RmiInvocationWrapper.invoke(RmiInvocationWrapper.java:72)
at sun.reflect.GeneratedMethodAccessor39.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:322)
at sun.rmi.transport.Transport$1.run(Transport.java:177)
at sun.rmi.transport.Transport$1.run(Transport.java:174)
at sun.rmi.transport.Transport.serviceCall(Transport.java:173)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:553)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:808)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:667)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: javax.persistence.RollbackException: java.lang.ClassCastException: org.apache.commons.dbcp.PoolableConnection cannot be cast to oracle.jdbc.OracleConnection
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:157)
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:513)
... 46 more
Please help me out to resolve this issue. And please confirm EclipseLink can be used to connect Oracle12 or not suppirted ?
Thanks in Advance.
[Updated on: Mon, 22 May 2017 05:18] Report message to a moderator
Re: problem when migrating from oracle11 to oracle12e [message #1763741 is a reply to message #1763682] |
Fri, 19 May 2017 09:06 |
Hello Chris ,
Thanks for the quick response.
Could you please share the ideal settings of eclipse link for connecting to oracle12 db .
Since it was working for ojdbc14 and oracle 11 , Am not finding what difference would be there to connect to oracle 12 g.
Please find the persistence XML file below
<?xml version="1.0" encoding="UTF-8" ?>
<persistence xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd"
version="2.0" xmlns="http://java.sun.com/xml/ns/persistence">
<properties>
<!-- Default database login using Oracle for EclipseLink's internal connection pool,
change this to access your own database. -->
<!-- property name="javax.persistence.jdbc.driver" value="oracle.jdbc.OracleDriver" />
<property name="javax.persistence.jdbc.url" value="jdbc:oracle:thin:@xxx.xxx.xxx.xxx:xxxx:xxxxx" />
<property name="javax.persistence.jdbc.user" value="xxxxx" />
<property name="javax.persistence.jdbc.password" value="xxxxx" /-->
<!-- The database platform is auto-detected by default,
if you want to set a specific platform this can be set. -->
<!-- property name=""eclipselink.target-database" value="Oracle" / -->
<!-- Optimize database writes to use batching. -->
<property name="eclipselink.jdbc.batch-writing" value="JDBC" />
<!-- Avoids flush being triggered before every query execution. -->
<property name="eclipselink.persistence-context.flush-mode" value="AUTO" />
<!-- Configure connection pool. -->
<property name="eclipselink.jdbc.connections.initial" value="1" />
<property name="eclipselink.jdbc.connections.min" value="64" />
<property name="eclipselink.jdbc.connections.max" value="64" />
<!-- In JSE no server platform is used, if you wish to use this example is a JEE server with JTA,
then you need to set this. -->
<!-- property name="eclipselink.target-server" value="WebLogic" / -->
<!-- Configure cache size. -->
<property name="eclipselink.cache.size.default" value="1000" />
<!-- If desired, this option would disable caching. -->
<property name="eclipselink.cache.shared.default" value="false"/>
<!-- If desired, this option would force a JDBC connection to be held for the duration of an EntityManager,
instead of returned to the pool in between queries/transactions. -->
<!-- property name="eclipselink.jdbc.exclusive-connection.mode" value="Always" / -->
<!-- Configure database to be created on startup if not already existing. -->
<!-- property name="eclipselink.ddl-generation" value="create-tables" /-->
<!-- To drop and replace existing schema this can be used. -->
<!-- property name="eclipselink.ddl-generation" value="drop-and-create-tables" / -->
<!-- Configure simple SQL logging for demonstration. -->
<property name="eclipselink.logging.level" value="OFF" />
<property name="eclipselink.logging.thread" value="false" />
<property name="eclipselink.logging.session" value="false" />
<property name="eclipselink.logging.exceptions" value="false" />
<property name="eclipselink.logging.timestamp" value="false" />
<!-- Configure custom Id generator. -->
<property name="eclipselink.session.customizer" value="com.cabpersistence.custom.eclipselink.UUIDSequence"/>
<!-- Configure custom descriptor customizers (for history support, could also be achieved using @Customizer annotation). -->
<!-- property name="eclipselink.descriptor.customizer.ItvModuleEntity" value="com.persistence.custom.eclipselink.RolloutPlanHistoryCustomizer"/>
<property name="eclipselink.descriptor.customizer.ItvContentEntity" value="com.persistence.custom.eclipselink.RolloutPlanHistoryCustomizer"/-->
</properties>
</persistence-unit>
</persistence>
Thanks again.
[Updated on: Mon, 22 May 2017 05:26] Report message to a moderator
FUDForum. Page generated in 0.03711 seconds
