Deploying RAP Mail onto Apache Karaf [message #1761889] |
Thu, 11 May 2017 15:53 |
Hi all,
I was wondering if anyone has experience in deploying RAP Mail on Karaf. Sometimes it's successfully deployed but sometimes the following exception occurs:
org.apache.karaf.features.internal.util.MultiException: Error restarting bundles
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:868)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_66]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_66]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_66]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_66]
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.registry.internal.Activator.start() of bundle org.eclipse.equinox.http.registry.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:392)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:411)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1287)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:860)[8:org.apache.karaf.features.core:4.0.8]
... 6 more
Caused by: java.lang.NullPointerException: null values not allowed
at org.eclipse.core.internal.registry.ReferenceMap.put(ReferenceMap.java:355)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getBundle(RegistryStrategyOSGI.java:151)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:166)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.http.registry.internal.HttpContextManager.added(HttpContextManager.java:75)
at org.eclipse.equinox.http.registry.internal.ExtensionPointTracker.open(ExtensionPointTracker.java:75)
at org.eclipse.equinox.http.registry.internal.HttpContextManager.start(HttpContextManager.java:47)
at org.eclipse.equinox.http.registry.internal.HttpRegistryManager.start(HttpRegistryManager.java:104)
at org.eclipse.equinox.http.registry.internal.HttpServiceTracker.addingService(HttpServiceTracker.java:58)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)[org.osgi.core-6.0.0.jar:]
at org.eclipse.equinox.http.registry.internal.HttpServiceTracker.open(HttpServiceTracker.java:42)
at org.eclipse.equinox.http.registry.internal.Activator.addingService(Activator.java:59)
at org.eclipse.equinox.http.registry.internal.Activator.start(Activator.java:37)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_66]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
... 15 more
Any insight would be greatly appreciated.
Thanks & Regards,
SetNug
Re: Deploying RAP Mail onto Apache Karaf [message #1763290 is a reply to message #1761921] |
Fri, 12 May 2017 11:38 |
Hi Chris,
Thank you for looking into this.
Looking at the code, the error caused by the following snippet:
bundle = Activator.getContext().getBundle(OSGiId);
which returns null, but since there's no log, it's not possible to know what OSGiId is.
Thanks & Regards,
SetNug
FUDForum. Page generated in 0.02933 seconds
