Re: State Machine Graphical Transition notation [message #1761254 is a reply to message #1761193] |
Tue, 09 May 2017 12:00 |
Concerning the effect behaviour: Papyrus does not support an activity-like representation within the state diagram (and this is not likely to change). However,
(1) you can create a separate activity diagram for an activity based behaviour (and optionally create a hyper-link).
(2) If the effect is an opaque behavior, you can show a specified number of lines of this behavior (controllable via Papyrus CSS, in particular "bodyCutLength")
Concerning the signal reception / five-pointed polygon: this is currently not supported as well and as far as I know there is no workaround. You might experiment with CSS to change the appearance for transitions which use a signal as trigger. If you think, that it is important to visually identify transitions with signal triggers, please post a bug with severity = Enhancement (component = Diagrams).
FUDForum. Page generated in 0.02866 seconds
