Re: Imported C++ registered package [message #1761219 is a reply to message #1760974] |
Tue, 09 May 2017 07:41 |
The ExtLibrary stereotype already supports the use of qualified names via the "prefix" attribute. However, this attribute is not set to "std::" in the STL model library and there is an error in the evaluation of this attribute. I will correct this two problems asap.
Re: Imported C++ registered package [message #1776040 is a reply to message #1776023] |
Thu, 09 November 2017 16:26 |
Since Papyrus-RT seems to be involved, I should mention that the STL is not supported by its code generatorand we therefore do not provide a type library for it.
We currently only support the ANSI C types and the UML primitive types, each having their own library that can be imported.
The UML type library does contain a "String" type that the code generator converts to "char *".
Please note that if you are using Papyrus-RT, there is a dedicated Papyrus-RT forum available.
/Charles Rivet
Re: Imported C++ registered package [message #1776767 is a reply to message #1776534] |
Tue, 21 November 2017 12:36 |
AttributeProperties is a stereotype of the Papyrus-RT C++ profile and is taken into account by the Papyrus-RT code generator. The use of the STL model library (coming with Papyrus-SW designer) in Papyrus-RT has not been intended, but seems to be ok - if you apply the additional stereotype.
If you use the code generation from Papyrus SW designer, you just type your class attribute with "string" from the STL model library, i.e. you don't need this stereotype.
Ansgar
FUDForum. Page generated in 0.04228 seconds
