Home » Eclipse Projects » GEF » Showing a Graph Zest inside of a Group widget(How to show a Graph zest in a SWT widget)
Showing a Graph Zest inside of a Group widget [message #1760625] Fri, 28 April 2017 23:19 Go to next message
I have created a Graph with Zest but I want to show it inside of my main window. This window has several components (a tabfolder and tabitems) and a button as is shown in the figure.
index.php/fa/29183/0/
I also create a Group widget called (Graph Result) and my ideia is to show my graph inside this group, but I do not know how to do it.
The following version of the code inside of the button works.
Display display = Display.getDefault();
ChildShell childShell = new ChildShell(display);
Algorithm algorithm = new Algorithm(xx, projectName, xx);
algorithm.createPartControl(childShell.getShell());
childShell.open();
But opens a new window. I thought this code could work but nothing happens:
MetricGraph mg = new MetricGraph(algorithm.getFanIn());
mg.createPartControl(graphGroup);
Is it possible to perform what i am thinking?
My MetricGraph class extends ViewPart.
Thank you!,
Daniel.
Re: Showing a Graph Zest inside of a Group widget [message #1760629 is a reply to message #1760625] Sat, 29 April 2017 02:14 Go to previous messageGo to next message
I am sorry, but given your code snippets and description it is unclear to me what do you want to achieve here, e.g. I have no idea what is an Algorithm or a MetricGraph.
However, Zest graph can easily be included in any kind of SWT composite the following way:
* Zest 1.x (SWT): new Graph(composite, SWT.NONE);
* Zest 1.x (JFace): new GraphViewer(composite, SWT.NONE);
* GEF 5 Zest (JFace): viewer = new ZestContentViewer(); viewer.createControl(composite, SWT.NONE);
I hope this helps; if not, please try to clarify the question.
Zoltán
Re: Showing a Graph Zest inside of a Group widget [message #1760643 is a reply to message #1760625] Sat, 29 April 2017 10:52 Go to previous message
Hello Zoltan,
Sorry by the explanation, I 'll try to be more accurate:
Algorithm class contains several methods that returns software metrics. One of them is the fanIn metric and I want to graph it (dependencies of methods). So this method, algorithm.getFanIn(), return a list of strings that I want to graph. For example, one string is conformed as nameMethodCall ---> nameMethodCalled.
The MetricGraph class graphs the strings above. I took the example from this site http://www.vogella.com/tutorials/EclipseZest/article.html
public void createPartControl(Composite parent)
		List<String> nodes = null;
		try {
			nodes = this.getCalls();
		} catch (SQLException e1) {
			e1.printStackTrace();
		} catch (QueryException e1) {
		} catch (IOException e1) {
		// Graph will hold all other objects
		graph = new Graph(parent, SWT.NONE);
		for (String node : nodes)
			String from = node.split("\\|")[0];
			String to = node.split("\\|")[1];
			GraphNode node1 = null;
			GraphNode node2 = null;
			if (contains(graph.getNodes(), from) == false)
				node1 = new GraphNode(graph, SWT.NONE, from);
			else
				node1 = searchNode(graph.getNodes(), from);
			if (contains(graph.getNodes(), to) == false)
				node2 = new GraphNode(graph, SWT.NONE, to);
			else
				node2 = searchNode(graph.getNodes(), to);
			// Change line color and line width
			GraphConnection graphConnection = new GraphConnection(graph, ZestStyles.CONNECTIONS_DIRECTED, node1, node2);
			graphConnection.changeLineColor(parent.getDisplay().getSystemColor(SWT.COLOR_GREEN));
			// Also set a text
			graphConnection.setText("This is a text");
			graphConnection.setHighlightColor(parent.getDisplay().getSystemColor(SWT.COLOR_RED));
			graphConnection.setLineWidth(3);
			//graph.setLayoutAlgorithm(new CompositeLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING, new LayoutAlgorithm[] { new DirectedGraphLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), new HorizontalShift(LayoutStyles.NO_LAYOUT_NODE_RESIZING) }),false);
			graph.setLayoutAlgorithm(new TreeLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), true);
			//graph.setLayoutAlgorithm(new SpringLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), true);
			// Selection listener on graphConnect or GraphNode is not supported
			// see https://bugs.eclipse.org/bugs/show_bug.cgi?id=236528
			graph.addSelectionListener(new SelectionAdapter() {
				public void widgetSelected(SelectionEvent e) {
					System.out.println(e);
This class (MetricGraph) extends ViewPart as the example of Vogella. In the main window of my plugin I want to graph the result of the fainIn metric:
//An instance of the metric class
//An instance of the graph class by passing the list of strings
//I want to graph the metric in a Group composite called graphGroup
It is clear that there is something that I do not understand. How can I graph the metric inside my graphGroup composite?
I can graph it in a new Shell called ChildShell by using this code:
btnFCA.addSelectionListener(new SelectionAdapter()
				Algorithm algorithm = new Algorithm(kdmFileFolder, projectName, kdmFile);
				childShell.open();
But of course, it opens another window.
I hope this explanation be better.
Than you,
Daniel.
[Updated on: Sat, 29 April 2017 11:53] by Moderator
Previous Topic:Trouble with Connection Content Parts (GEF4 0.4.0)
Next Topic:Drag & drop in parent - child relation
Current Time: Fri Jun 20 10:46:45 EDT 2025
Powered by FUDForum. Page generated in 0.27130 seconds
