EVL: Problem on configuring a UML model [message #1760453] |
Thu, 27 April 2017 12:58 |
Alireza Rouhi Messages: 148 Registered: December 2015 |
Hi all,
I encounter an odd problem regarding a UML model configuration to validate by an EVL module. The list of metamodels which my UML model conforms to them is missed now! I attached the two windows here. I have not this problem before. Now, I am using Eclipse Mars 2 release and Epsilon 1.5.
Please, help me to resolve this issue.
Thanks a million
Alireza
[Updated on: Thu, 27 April 2017 14:37] Report message to a moderator
Re: EVL: Problem on configuring a UML model [message #1760488 is a reply to message #1760487] |
Thu, 27 April 2017 16:51 |
You're right.
Printing the Profile.all statement yields an empty sequence. Of course, as you can see in the attached screen shot, the profile has been registered and I can apply the stereotypes on my model.
I am using my profiles as plugins. I simply copy the plugins into the eclipse's plugins subfolder. How can I register them?
Alireza
[Updated on: Thu, 27 April 2017 16:58] Report message to a moderator
Re: EVL: Problem on configuring a UML model [message #1760618 is a reply to message #1760504] |
Fri, 28 April 2017 22:24 |
Hi Alireza,
I've reproduced the problem. We plan to spend more time on understanding the EMF magic that Eclipse UML does under the hood over the next few months and we'll look at this then. In the meantime, you can add your UML model as a regular EMF model to your launch configuration and add the missing metamodels manually. Apologies for any inconvenience caused.
Dimitris
FUDForum. Page generated in 0.06496 seconds
