Home » Eclipse Projects » e(fx)clipse » How do I install e(fx)clipse 2.5.0?(Problems with documentation)
icon5.gif  How do I install e(fx)clipse 2.5.0? [message #1760113] Sat, 22 April 2017 19:45 Go to next message
Hi community,
I am new to e(fx)clipse and I am having trouble finding current information about how to install the latest stable version (according to what I read is 2.5.0).
I think it would be a good idea to have a sticky post in this forum (if that is possible) describing how to install the latest stable version, and should be updated once a new version is released. Most likely that will mean just updating the software urls for the ide and the runtime, and new users will know exactly what to do.
I tried installing the nightly versions (3.0.0) and they do install. The problem is that the wizards seem to be broken. It is impossible to open the sample application and if I create a new e4 application it is mainly empty. I know from pictures from old tutorials that show version 2.0.0 that the wizards should create a functioning application that one could review and modify.
This is the link that says 2.5.0 is the current release:
https://projects.eclipse.org/projects/technology.efxclipse
The following links show outdated information:
https://wiki.eclipse.org/Efxclipse/Tutorials/AddingE(fx)clipse_to_eclipse#Setup_a_target_platform_for_your_application_development
http://o7planning.org/en/10619/install-efxclipse-into-eclipse
https://www.eclipse.org/efxclipse/install.html#for-the-lazy
https://www.eclipse.org/efxclipse/install.html#for-the-ambitious
Anyway, I would not mind to work with the nightly version, but I need the wizards. Otherwise I would need the latest stable urls for both the ide and the runtime.
Thanks!
Re: How do I install e(fx)clipse 2.5.0? [message #1760122 is a reply to message #1760113] Sun, 23 April 2017 07:39 Go to previous messageGo to next message
Hope this helps:
https://www.eclipse.org/forums/index.php?t=msg&th=1084701&goto=1759548&#msg_1759548
Re: How do I install e(fx)clipse 2.5.0? [message #1760136 is a reply to message #1760122] Sun, 23 April 2017 12:06 Go to previous message
Yes latest stabel IDE tooling release is 2.4.0 - in what version of Eclipse did you try to install the nightly? Why does the prepackaged version does not work for you?
Previous Topic:In Linux Mint Eclipse don't refresh fxml after Scene Builder edit
Next Topic:Threading: SWT events/ FX events
Current Time: Fri Sep 12 06:50:16 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
