Home » Newcomers » Newcomers » Java import statement hints
Java import statement hints [message #1759764] Tue, 18 April 2017 05:35 Go to next message
I'm learning Java and am importing a package to try out the Calendar class.
import java.util.Calendar.*;
The problem is quite often the template proposal window that comes up seems to be inconsistent and a class that I know exists is sometimes offered and sometimes not in the proposal window. Please see attached images and you will see what I mean.
Why is this and how can I correct it?
index.php/fa/29072/0/
index.php/fa/29073/0/
  • Attachment: Capture1.PNG
    (Size: 35.25KB, Downloaded 1879 times)
  • Attachment: Capture0.PNG
    (Size: 44.24KB, Downloaded 1447 times)
[Updated on: Tue, 18 April 2017 05:36] by Moderator
Re: Java import statement hints [message #1759771 is a reply to message #1759764] Tue, 18 April 2017 07:18 Go to previous messageGo to next message
Yes, it seems often it wants to propose package names, and once it starts proposing package names, even typing a "." will then show only package names and not class names. After you type a "." you can hit Ctrl-space a bunch of times to cycle through the proposal types, and then it shows class. In general though, I never ever try to complete imports in this way. I just use a class in context and then complete it there, which then generated the appropriate import. So I'd suggest you get out of the habit of ever typing an import statement and trying to complete it. Just start typing the name of the class at the point where you want to use it, and complete it there...
Re: Java import statement hints [message #1759782 is a reply to message #1759771] Tue, 18 April 2017 09:23 Go to previous message
Yes that seems to work and saves me having to write import statements. Thanks for the suggestion Smile
Previous Topic:Permissions problems in my workspace (self-caused, self-resolved)
Next Topic:The nested constructor "new A(new B(x))"
Current Time: Mon Oct 27 04:05:40 EDT 2025
Powered by FUDForum. Page generated in 0.20481 seconds
