Re: Java for Windows missing [message #1760107 is a reply to message #1759744] |
Sat, 22 April 2017 18:13 |
Eugenio Estrada Messages: 8 Registered: April 2017 |
Ed, thanks a lot for your answer,
I was far from PC and internet last days,
the command gets
java versión "1.8.0_121"
Java (TM) SE Runtime Enviroment (build 1.8.0_121-b13)
Java HotSpot (TM) Client VM (build 25.121-b13, mixed mode)
Have I to understand from this, that Java resides on Windows folder?
By the other side I found Java
C:\Program Files (x86)\Java\jre1.8.0_121
Windows always surprises me, I have Java installed at
C:\Archivos de Programa (x86)\Java\jre1.8.0_121
since It is "spanish" PC, but when I copy the link, It converts to
C:\Program Files (x86)\Java\jre1.8.0_121 (??)
Eclipse files "are" in C:\Program Files\Eclipse but the folder is empty
Could be It the evil??
Should I to configure Java Setup??
thanks again
Eugenio
[Updated on: Sat, 22 April 2017 22:01] Report message to a moderator
Re: Java for Windows missing [message #1760147 is a reply to message #1760134] |
Sun, 23 April 2017 19:06 |
thanks again Ed for your dedicated time,
W10 is 64 bits, downloaded Java was 64 bits and selected Eclipse was 64 bits
I paid attention at that issue at download time
right now, before end this post I tested on java website, and Java says there was a new versión versión 8 update 131, so I downladed and installed,
After It and after restart W10, I tried again and Eclipse keeps without to recognize Java installation, again at Java website, Test for Java installation says Java is installed ok.
About "Program Files" versus "Archivos de Programa" folders,
until I understand, when I select "Spanish" language for an application, It will be installed at "Archivos de Programa" folder, by the other hand, english apps will be installed at "Program Files" folder.
I guess I can uninstall Java and reinstall at "Program Files" folder, since that during installation process It ask about choose an alternative folder.
thanks a lot
Eugenio
FUDForum. Page generated in 0.10280 seconds
