How To: Enter a semicolon with external key combination [message #1758877] |
Tue, 04 April 2017 06:16 |
Dominik Gabriel Messages: 113 Registered: June 2013 |
hi there,
i got a problem with the external key combination. i am trying to enter a ';' by using it, but thats not working. i am always getting Invalid Base Key ... or Execution Error: "The validated object is null"
i am using the german keyboard layout. here's what i already tried:
| modifier_key | base_key |
| none | ; |
| shift | , |
| shift | \, |
| none | \; |
can anybody help me?
best regards
dominik
[Updated on: Tue, 04 April 2017 06:17] Report message to a moderator
Re: How To: Enter a semicolon with external key combination [message #1759386 is a reply to message #1759379] |
Tue, 11 April 2017 07:49 |
Hi Dominik,
I just tried it in the RCP SimpleAdder as well and I can confirm your observations. Previously, I tested it with the JavaFX SimpleAdder and there it's working fine so this is an RCP problem.
If you just need a semicolon as text, you could make a simple workaround by using copyToClipboard and pasting the clipboard with CTRL + V modifier key. Please let us know if you need it for a case where pasting from the clipboard is not a suitable workaround, we will then try to fix it until the next release. I also already filed a bug ticket [1].
Kevin
[1] http://eclip.se/515078
Re: How To: Enter a semicolon with external key combination [message #1759566 is a reply to message #1759390] |
Thu, 13 April 2017 08:18 |
Hi Dominik,
could you please try it again with the unbound module "ub_app_externalPressAnyKey [MODIFIER_KEYS; BASE_KEY]". As for the parameters enter MODIFIER_KEYS: shift and BASE_KEY: COMMA. This worked for me in SWT. There are two sorts of key combinations: External Key Combination and just Key Combination. Key Combination is the faulty one but External Key Combination seems to work.
Kevin
FUDForum. Page generated in 0.04217 seconds
