| Re: A way to disable the default popup menu (right clicking on editable cell)? [message #1758649 is a reply to message #1758638] | Fri, 31 March 2017 03:28   |  |
| Eclipse User  |  |  |  |  | The popup menu you see is the native menu of the SWT Text control. To get rid of it you need a customized TextCellEditor where you customize the created Text control.
 To disable the context menu completely you could do this like this:
 configRegistry.registerConfigAttribute(
        EditConfigAttributes.CELL_EDITOR,
        new TextCellEditor() {
            public Text createEditorControl(Composite parent) {
                Text textControl = super.createEditorControl(parent);
                // disable context menu in Text field
                textControl.addMenuDetectListener(new MenuDetectListener() {
                    public void menuDetected(MenuDetectEvent e) {
                        e.doit = false;
                return textControl;
        DisplayMode.NORMAL,
        ColumnLabelAccumulator.COLUMN_LABEL_PREFIX + "0");
 To attach a custom Menu it would look like this:
        new TextCellEditor(true, true) {
                Menu menu = new Menu(textControl);
                MenuItem item = new MenuItem(menu, SWT.PUSH);
                item.setText("Custom item");
                textControl.setMenu(menu);
                return textControl;
        DisplayMode.NORMAL,
 To use the menu you registered the NatTable way, you would need to connect your configuration with your MenuConfiguration and get the SWT Menu from there.
FUDForum. Page generated in 0.04378 seconds
