Home » Newcomers » Newcomers » Unable to Add or clone a Git Repository Neon.3(GIT Integration)
Unable to Add or clone a Git Repository Neon.3 [message #1758466] Tue, 28 March 2017 21:05 Go to next message
On my Neon.3 system, after running the Eclipse updates, I had the following error on the Git Repositories perspective.
java.nio.file.InvalidPathException: Illegal char <"> at index 0: \.gitconfig
I deleted the .metadata folder in the workspace folder cleared the above error but I am not unable to add in the existing local Git repositories or clone an existing Git repository. Uninstalling and reinstalling Eclipse does not correct the issue.
The repositories are seen in the wizard but are not added to the perspective when finished is clicked.
I have another machine that is still running Neon.2 and it is able to view and add Git repositories as can my older Kepler machine.
Re: Unable to Add or clone a Git Repository Neon.3 [message #1758474 is a reply to message #1758466] Tue, 28 March 2017 23:08 Go to previous messageGo to next message
Please attach whatever is in that .pdf file directly. And you might want to look at the contents of ~/.gitconfig, which would seem to be what it's complaining about, and see if anything looks amiss.
Re: Unable to Add or clone a Git Repository Neon.3 [message #1758530 is a reply to message #1758474] Wed, 29 March 2017 12:49 Go to previous message
I searched for the .gitconfig on the affected machine and the file is not present any where in the file structure.
Is there a process for recreating the .gitconfig file?
[EDIT]
I tried copying the .gitconfig from a machine that has the file over to the affected machine. It looks like Eclipse is having difficulty parsing the .gitconfig file path. It seems to be complaining about the double quotation mark (") in the file path
org.eclipse.e4.core.di.InjectionException: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Users\mrosenha"\.gitconfig
[Updated on: Wed, 29 March 2017 13:46] by Moderator
Previous Topic:org.eclipse.wst.server.core is missing
Next Topic:Project closed in workspace, dependency added in ivy.xml, but still eclipse throws error
Current Time: Sun Sep 21 19:55:34 EDT 2025
Powered by FUDForum. Page generated in 0.07479 seconds
