How to remove padding value from perspective's page layout [message #1758247] |
Sat, 25 March 2017 19:29 |
Sudesh Bulathsinhala Messages: 193 Registered: October 2010 |
We use theme contribution to extend the existing RAP default theme. We have 2 perspectives to implement the login and it works well. By default when start, the login perspective is loaded, and when the user/pass credentials are processed and valid, we unload the login perspective and load the client perspective, where application module constructs are placed.
We are required to remove the padding from left panel. please find the attachment.
(the space between top, left and bottom should be removed, and this should be ok, as we don't place other views editor in login perspective).
Any idea ?
Sudesh
Attachment: expected.png
(Size: 53.41KB, Downloaded 217 times) -
Attachment: log_in.png
(Size: 60.17KB, Downloaded 198 times)
[Updated on: Sat, 25 March 2017 19:54] Report message to a moderator
FUDForum. Page generated in 0.08881 seconds
