Home » Eclipse Projects » RCP Testing Tool » How to wait for workspace build(Making the RCP Test Runner to wait only for workspace build)
How to wait for workspace build [message #1756396] Thu, 16 March 2017 07:45 Go to next message
Currently I can only write below command to wait for a specific amount of time.
wait -ms 72000
As this is not idle to wait for a random amount of time,
sometime the build finishes way too quicker and some times it takes ages
depending on the load of the server apart from the actual task in Test Application (eclipse IDE).
Is there any way to wait for completion of any building workspace job/task.
Re: How to wait for workspace build [message #1757813 is a reply to message #1756396] Mon, 20 March 2017 05:03 Go to previous messageGo to next message
can you check the task completion within the testcase?
If yes you could wait in a loop:
  loop [val index [int 0]] {
        if [!check if task completed]
            if [$index | lt $maxIterationDefinedElsewhere] {
              wait $msToWait
              recur [$index | plus 1]
Re: How to wait for workspace build [message #1757814 is a reply to message #1756396] Mon, 20 March 2017 05:03 Go to previous messageGo to next message
              wait $msToWait
Re: How to wait for workspace build [message #1757815 is a reply to message #1757814] Mon, 20 March 2017 05:20 Go to previous messageGo to next message
Hello Markus,
Thanks for the reply and the logic.
Do you know how can I check the task completion of a work-space build?
Do you any piece of code?
Ramesh.
Re: How to wait for workspace build [message #1757816 is a reply to message #1757814] Mon, 20 March 2017 05:21 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 20 March 2017 05:23] by Moderator
Re: How to wait for workspace build [message #1757906 is a reply to message #1757815] Tue, 21 March 2017 11:42 Go to previous message
No I am sorry.
Perhaps you can check by created artifacts with get-file <artifact> | get exists
Previous Topic:Feature: Test script active while AUT is off
Next Topic:RCPTT + GEF: scrolling does not work
Current Time: Sat Sep 06 09:28:14 EDT 2025
Powered by FUDForum. Page generated in 0.04016 seconds
