Re: Overloaded method determination [message #1755871 is a reply to message #1755846] |
Wed, 08 March 2017 18:25 |
Idea: Store the signature infos in the xtext index / scope entries and adapt scoping.
lets start with a way way way less complicated grammar
Model:
functions+=Function*
calls+=Call*;
Function:
"func" name=ID '(' (types+=DeclaredParameter (',' types+=DeclaredParameter)*)? ')' ':' returnType=Type
DeclaredParameter:
name=ID ":" type=Type
Expression:
Literal | Call
Literal:
IntegerLiteral | StringLiteral
IntegerLiteral:
value=INT
StringLiteral:
value=STRING
enum Type: String | Integer;
Call:
func=[Function] '(' (params+=Expression (',' params+=Expression)*)? ')'
// indexing
class MyDslResourceDescriptionStrategy extends DefaultResourceDescriptionStrategy {
private final static Logger LOG = Logger.getLogger(MyDslResourceDescriptionStrategy);
override createEObjectDescriptions(EObject eObject, IAcceptor<IEObjectDescription> acceptor) {
if (eObject instanceof Function) {
if (getQualifiedNameProvider() === null)
return false;
try {
val QualifiedName qualifiedName = getQualifiedNameProvider().getFullyQualifiedName(eObject);
if (qualifiedName !== null) {
val userData = newHashMap
if (eObject.returnType !== null) {
userData.put("RETURN_TYPE", eObject.returnType.literal)
userData.put("PARAM_TYPES", eObject.types.map[type.literal].join(","))
acceptor.accept(EObjectDescription.create(qualifiedName, eObject, userData));
} catch (Exception exc) {
LOG.error(exc.getMessage(), exc);
return true;
return super.createEObjectDescriptions(eObject, acceptor)
// scope entries for local file
class MyDslImportedNamespaceAwareLocalScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
override protected internalGetAllDescriptions(Resource resource) {
var Iterable<EObject> allContents = new Iterable<EObject>() {
override Iterator<EObject> iterator() {
return EcoreUtil.getAllContents(resource, false)
var Iterable<IEObjectDescription> allDescriptions = scopedElementsFor(allContents, qualifiedNameProvider)
return new MultimapBasedSelectable(allDescriptions)
def static <T extends EObject> Iterable<IEObjectDescription> scopedElementsFor(Iterable<? extends T> elements,
Function<T, QualifiedName> nameComputation) {
var Iterable<IEObjectDescription> transformed = Iterables.transform(elements, [ T from |
val QualifiedName qualifiedName = nameComputation.apply(from)
if (from instanceof org.xtext.example.mydsl1.myDsl.Function) {
if (from.returnType !== null) {
userData.put("RETURN_TYPE", from.returnType.literal)
userData.put("PARAM_TYPES", from.types.map[type.literal].join(","))
return new EObjectDescription(qualifiedName, from, userData)
return new EObjectDescription(qualifiedName, from, null)
return Iterables.filter(transformed, Predicates.notNull())
// scope provider
class MyDslScopeProvider extends AbstractMyDslScopeProvider {
override getScope(EObject context, EReference reference) {
if (reference === MyDslPackage.Literals.CALL__FUNC) {
if (context instanceof Call) {
val actualSignature =
context.params.map[
p |
if (p instanceof StringLiteral) {
return Type.STRING.literal
if (p instanceof IntegerLiteral) {
return Type.INTEGER.literal
if (p instanceof Call) {
return p.func.returnType.literal
].join(",")
return new FilteringScope(delegateGetScope(context, reference)) [
val sig = getUserData("PARAM_TYPES")
if (sig !== null) {
return actualSignature == sig
return true
super.getScope(context, reference)
// bindings
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
def Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
override configureIScopeProviderDelegate(Binder binder) {
binder.bind(IScopeProvider).annotatedWith(Names.named(AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(
MyDslImportedNamespaceAwareLocalScopeProvider);
Twitter : @chrdietrich
FUDForum. Page generated in 0.06372 seconds
