Home » Eclipse Projects » EclipseLink » Exception in thread "main" Local Exception Stack: (JPA with Eclipselink)
icon11.gif  Exception in thread "main" Local Exception Stack: [message #1755712] Tue, 07 March 2017 02:22 Go to next message
Please take more details on the attachements. Im out of ideas.
Im trying to implement an JPA project but always go the followings errors:
Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: sun.misc.Launcher$AppClassLoader@2a139a55
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [Customers] failed.
Internal Exception: Exception [EclipseLink-7212] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
Exception Description: The attribute [updateTime] from the entity class [class cm.wattsohn.Customers] does not specify a temporal type. A temporal type must be specified for persistent fields or properties of type java.util.Date and java.util.Calendar.
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(PersistenceUnitLoadingException.java:127)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:107)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:177)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:79)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:54)
at cm.wattsohn.TestCustomers.main(TestCustomers.java:15)
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.createPredeployFailedPersistenceException(EntityManagerSetupImpl.java:1954)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1945)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:96)
... 4 more
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:230)
... 8 more
Caused by: Exception [EclipseLink-7212] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
at org.eclipse.persistence.exceptions.ValidationException.noTemporalTypeSpecified(ValidationException.java:1461)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processTemporal(MappingAccessor.java:1970)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingConverter(MappingAccessor.java:1773)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.MappingAccessor.processMappingValueConverter(MappingAccessor.java:1796)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.BasicAccessor.process(BasicAccessor.java:419)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.VersionAccessor.process(VersionAccessor.java:104)
at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processMappingAccessors(MetadataDescriptor.java:1536)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processMappingAccessors(ClassAccessor.java:1648)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processMappingAccessors(EntityAccessor.java:1234)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:697)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1793)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:576)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:585)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1869)
... 6 more
What am I doing wrong ?
Re: Exception in thread "main" Local Exception Stack: [message #1755870 is a reply to message #1755712] Wed, 08 March 2017 13:24 Go to previous message
The error states you are missing something on the updateTime attribute of the Customer entity. Because it is a java.util.Date, JPA needs you to specify if you want it treated like a java.sql.Date or java.sql.Timestamp as it can go either way: " A temporal type must be specified for persistent fields or properties of type java.util.Date and java.util.Calendar.".
For example:
@Version
@Column(name = "LAST_UPDATE")
@Temporal(TemporalType.TIMESTAMP)
private Date updateTime;
Is probably what you want since you are using it as a version field.
Previous Topic:Eclipselink error 3002
Next Topic:Usage of QueryHint INHERITANCE_OUTER_JOIN
Current Time: Mon Sep 22 06:06:36 EDT 2025
Powered by FUDForum. Page generated in 0.02947 seconds
