Should I need to start Eclipse twice for RCP support? [message #1755442] |
Fri, 03 March 2017 11:59 |
Kev James Messages: 22 Registered: November 2014 |
As you may have seen from a couple of other posts, I'm working on getting Jenkins to build my plugin, stand up a brand new Eclipse environment, and run my Jubula Test Suite.
What I'm seeing right now is that when I create my new environment (unzip eclipse to new directory), copy the org.eclipse.jubula.rc.rcp plugin over, and modify config.ini, I still need to start Eclipse twice to get the plugin to register/start up correctly.
The first time I start Eclipse, I get the org.eclipse.jubula.rc.rcp plugin listed in installation details. Second time I get:
org.eclipse.jubula.rc.rcp.common
org.eclipse.jubula.rc.rcp.e4
org.eclipse.jubula.rc.rcp.e4.swt
org.eclipse.jubula.rc.rcp.swt
At this point it will connect to Jubula as an AUT.
Is there a way to get all these plugins to be 'installed' on the first run? Or do I need to get my jenkins test to start, stop, start eclipse?
KEv.
FUDForum. Page generated in 0.02610 seconds
