| The requested resource is not available. [message #1755362] |
Thu, 02 March 2017 11:18  |
Hi all,
I've birt in /var/tomcat7 which is a link to /home/birt. I'm using java version "1.7.0_95".
If I connect to http://localhost:8080/birt , I have:
BIRT viewer has been installed.
Thank you for your choosing BIRT (Business Intelligence Reporting Tool).
Viewer Version : 3.7.2
Engine Version: 3.7.2
JRE version: 1.7.0_95
View Example
so it looks good. But if I click on View Example (http://localhost:8080/birt/frameset?__report=test.rptdesign&sample=my+parameter), I've a 404 (The requested resource is not available.).
Here is my birt folder :
[root@localhost] /home/birt> ls -la
total 108
drwxr-xr-x 9 zabbix tomcat7 4096 Mar 2 11:50 .
drwxr-xr-x 9 root root 4096 Feb 16 16:20 ..
drwxr-xr-x 7 root root 4096 Sep 18 2013 birt
-rwxr-xr-x 1 zabbix tomcat7 1703 Feb 14 2012 CancelTask.jsp
drwxr-xr-x 2 zabbix tomcat7 4096 Feb 18 2014 documents
-rwxr-xr-x 1 zabbix tomcat7 3328 Feb 14 2012 index.jsp
drwxr-xr-x 2 zabbix tomcat7 4096 Mar 13 2014 logs
lrwxrwxrwx 1 root root 30 Feb 16 16:28 prod -> /mountgluster/medias/var/birt/
drwxr-xr-x 3 zabbix tomcat7 4096 Feb 14 2012 report
lrwxrwxrwx 1 root root 39 Feb 16 16:28 Resources -> /mountgluster/medias/var/birt/Resources
drwxr-xr-x 2 zabbix tomcat7 4096 Feb 14 2012 scriptlib
-rwxr-xr-x 1 zabbix tomcat7 57161 Feb 14 2012 test1.rptdesign
-rwxr-xr-x 1 zabbix tomcat7 4772 Feb 14 2012 test.rptdesign
drwxr-xr-x 3 zabbix tomcat7 4096 Feb 14 2012 webcontent
drwxr-xr-x 5 zabbix tomcat7 4096 Mar 2 12:18 WEB-INF
But, problem, I've no log. tomcat is running, it works for the other webapps, not for birt ...
I did first a rsync from a server where birt works, it was wrong. I deployed the birt.war, same thing.
I don't know why. In fact, I don't know what I have to looking for ...
Do you have an idea ?
FUDForum. Page generated in 0.23790 seconds
