Problem with comparison [message #1755014] |
Sun, 26 February 2017 17:41 |
Banafsheh Azizi Messages: 328 Registered: July 2016 |
this if condition return false but When I debug "ve.refImmediateComposite()" and "thisModule.aux" both of them return "IN1!<unnamed>". Would any one help me in this regard?
if (ve.refImmediateComposite() = thisModule.aux)
Member of MDSE Research Group
http://mdse.ui.ac.ir
Re: Problem with comparison [message #1755701 is a reply to message #1755659] |
Mon, 06 March 2017 21:22 |
louis andia. wrote on Mon, 06 March 2017 16:19It's look like PropertyCallExpression don't have attribute named "method" and yours if don't return any boolean.
Yes, "PropertyCallExpression" doesn't have the attribute named "method". I want to navigate from self to "FOLMethodCallExpression" class which has a "method" feature. "FOLMethodCallExpression" is a sub-class of sub-class of self.
You wanted to write something like that?
if ((self.oclIsTypeOf(MM_ETL!PropertyCallExpression) or thisModule.isAHelper(self)) and not self.oclIsKindOf(MM_ETL!FOLMethodCallExpression).oclIsUndefined())
then (self.oclIsKindOf(MM_ETL!FOLMethodCallExpression).method.name = 'collect')
else false endif
No, the code I write above is a part of my code. It returns boolean value.
[Updated on: Mon, 06 March 2017 21:23] Report message to a moderator
Re: Problem with comparison [message #1755782 is a reply to message #1755758] |
Wed, 08 March 2017 07:12 |
I have also another question, the below if condition always return false.
if (MM_ETL!TransformationRule -> allInstances() -> exists (l|l.lazy=true and l.source.resolvedType.elementName.oclIsKindOf(MM_Src!EStructuralFeature.allInstances() -> select (s|s.name=a.target.collectAllContainedElements()->last().name)-> collect (s|s.eType)->first())))
I think because the below part of it returns "IN_trg!className"
and the below code returns "className"
MM_ETL!TransformationRule -> allInstances() -> collect (l|l.source.resolvedType.elementName)
I want if the "className" of second part I show is the same as "className" of the first part or one of its subtypes, the if condition returns true. would you please help me in this regard?
[Updated on: Wed, 08 March 2017 08:14] Report message to a moderator
FUDForum. Page generated in 0.04030 seconds
