Home » Modeling » TMF (Xtext) » [SOLVED] Bring rule call and cross-reference under one feature
[SOLVED] Bring rule call and cross-reference under one feature [message #1754924] Fri, 24 February 2017 02:44 Go to next message
Hi all,
In my DSL, I have types, which can be complex (i.e. objects) or simple (i.e. primitives like string, integer etc.)
A source in my DSL looks like this:
type SomeType {
    string primitiveAttribute
type OtherType {
    string otherPrimitiveAttribute
    SomeType complexAttribute
The grammar with which I achieve this is the following:
SimpleType:
	type = ('long' | 'string' | 'bool' | 'decimal' | 'integer')
ComplexType:
	'type' name = ID '{'
		(fields += TypeField)*
TypeField:
	typeDef = TypeDef fieldName = ID
TypeDef:
	(simpleType = SimpleType | typeRef = [ComplexType])
As you can see, SimpleType and ComplexType are assigned to two different features (I hope I get the terminology right), so when I generate something from them, I always have to handle these separately, checking if one of them is null, and so on. Also, their interfaces generated by Xtext are of course derived from EObject.
Is it possible to define a new rule which can hold SimpleType and ComplexType together in the TypeDef rule (so no null check is needed for their presence), and where both of them can derive from the same parent interface? It would be much better to have a common abstraction for them in my generator design.
Thank you.
[Updated on: Fri, 24 February 2017 03:36] by Moderator
Re: Bring rule call and cross-reference under one feature [message #1754927 is a reply to message #1754924] Fri, 24 February 2017 02:59 Go to previous messageGo to next message
thy not use inhertiance?
TypeDef:
SimpleType | ComplexTypeRef
ComplexTypeRef:
Re: Bring rule call and cross-reference under one feature [message #1754932 is a reply to message #1754927] Fri, 24 February 2017 03:35 Go to previous message
Great, thanks! I could have guessed that.
Previous Topic:Problems when referencing Ecore elements using an imported Ecore model
Next Topic:Implicitly add method call to generated interface.
Current Time: Fri Nov 07 15:31:06 EST 2025
Powered by FUDForum. Page generated in 0.02873 seconds
