| Problems when referencing Ecore elements using an imported Ecore model [message #1754821] |
Wed, 22 February 2017 13:47  |
in a new DSL I started to work on, I refer to Ecore elements in the DSL, something like
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
generate myDsl "...my uri..."
Program:
('metamodel' metamodels+=[ecore::EPackage|STRING])*
So far so good, everything works. Now I'd like to switch to a manually maintained ecore model. I performed the steps to switch to an imported ecore model (starting from the one that Xtext had previously generated).
As soon as I switch in the grammar:
import "...my uri..."
The grammar editor starts complaining with a warning for the import:
"The imported package refers to elements in the package registry
instead of using the instances from the workspace"
and for the assignment metamodels+=[ecore::EPackage|STRING]) I get an error:
"Cannot find compatible feature metamodels in sealed EClass
Program from imported package myuri:
The type 'EPackage' [org.eclipse.emf.ecore.EPackage] used in
the reference 'metamodels' is inconsistent. Probably this is
due to an unsupported kind of metamodel hierarchy."
However, the workflow mwe2 still runs (of course, I updated it so that it references my genmodel).
The warning (not the error) proposes a quickfix to "update the imported package". The quickfix transforms in my ecore the reference:
<eStructuralFeatures xsi:type="ecore:EReference" name="metamodels" unique="false"
upperBound="-1" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EPackage"/>
into
upperBound="-1" eType="ecore:EClass ../../../org.eclipse.emf.ecore/model/Ecore.ecore#//EPackage"/>
Now the editor is happy (no more errors nor warnings). However, now it is the mwe2 workflow that complains with the same error I used to have in the editor:
"Cannot find compatible feature metamodels in sealed EClass EdeltaProgram from imported package ...myuri...: The type 'EPackage' used in the reference 'metamodels' is inconsistent. Probably this is due to an unsupported kind of metamodel hierarchy. (ErrorCode: CannotCreateTypeInSealedMetamodel)"
is there anything I could do to make "everyone" happy?
Could this be related https://github.com/eclipse/xtext-core/issues/41?
thanks in advance
Lorenzo
| Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754892 is a reply to message #1754855] |
Thu, 23 February 2017 11:02  |
Christian Dietrich wrote on Thu, 23 February 2017 04:17i assume you should use "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore"
If Xtext tooling is the limit of your modeling aspirations, platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore may be convenient since you benefit from an Xtext-ism (? the Xtext index) whereby Xtext tooling doesn't actually use the Ecore.ecore that you say should be used.
However if you want to use your *.xtext model in another regular tool, in my case in an Xtext2LPG M2M, you need to use a correct reference; the nsURI.
I have no idea why the nsURI reference does not work for you, but without seeing all your tooling, who knows what magic you may have accidentally done.
Ed Willink
FUDForum. Page generated in 0.31406 seconds
