Home » Archived » Jubula » Problem working with Menu Bars(Unable to access Menu Bar)
Problem working with Menu Bars [message #1754294] Thu, 16 February 2017 04:05 Go to next message
I have a JavaFX AUT, for which I am carrying out GUI automation.
I have a MenuBar on my AUT, on accessing the MenuBar a dialog appears having some fields with OK and CANCEL buttons.
So, when I try to automate the test case as below,
1. MenuBar -> Select Menu Item -> Dialog appears -> Select all the fields -> click OK -> Verify if tab created with the selected fields. (Test case success)
2. MenuBar -> Select Menu Item -> Dialog appears -> Select all the fields -> click CANCEL -> Verify if tab created with the selected fields. (Test case failed).
Error :
Status: Step Failed
Type: Action Error
Error Description : Operation not supported by selected toolkit
Component Type: Menu Bar component
Action Type : Select menu entry by textpath.
Please help me to resolve this issue.
Om
Re: Problem working with Menu Bars [message #1754297 is a reply to message #1754294] Thu, 16 February 2017 04:14 Go to previous messageGo to next message
Hi again,
I think this is cause by the same problem that I've described here: https://www.eclipse.org/forums/index.php/m/1754288/#msg_1754288 (Multiple MenuBars)
Re: Problem working with Menu Bars [message #1754300 is a reply to message #1754297] Thu, 16 February 2017 04:16 Go to previous message
Hi Marcel,
Oh! Could you please help me resolve this issue.
Om
Previous Topic:executable command for export project
Next Topic:Comment for test results using testexec
Current Time: Fri Oct 31 03:01:29 EDT 2025
Powered by FUDForum. Page generated in 0.10483 seconds
