Home » Eclipse Projects » Eclipse Platform » "unable to retrieve the bundle ..." when Eclipse Neon2 is opening(error about the plugin org.eclipse.e4.ui.workbench)
"unable to retrieve the bundle ..." when Eclipse Neon2 is opening [message #1752830] Fri, 27 January 2017 19:15 Go to next message
This message (among others) appears when I open Eclipse Neon2 (even if there is no open project):
"Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.tools.emf.ui/org.eclipse.e4.tools.emf.ui.internal.handlers.MarkDuplicateElementIdsHandler".
Another error message about org.eclispe.equinox.registry plugin:
"Plug-in org.springframework.ide.eclipse.uaa was unable to load class org.springframework.ide.eclipse.internal.uaa.Startup."
with the exception trace:
"java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.springframework.ide.eclipse.uaa (576)....
Caused by: java.lang.ClassNotFoundException: org.bouncycastle.asn1.DEREncodable cannot be found by org.springframework.roo.wrapping.bcpg-jdk15_1.45.0.0001"
Have you an idea for solving them?
Thanks a lot
Re: "unable to retrieve the bundle ..." when Eclipse Neon2 is opening [message #1752987 is a reply to message #1752830] Tue, 31 January 2017 12:12 Go to previous message
The second message suggests that you are running STS, not vanilla Eclipse.
The first message suggests that you had installed the Eclipse Tools but have since uninstalled them. You can probably ignore that.
Previous Topic:EMF Update Site for emf.ecore.xcore
Next Topic:Oxygen M5 refuses to update
Current Time: Sat Jul 26 19:53:42 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
