Home » Eclipse Projects » GEF » FXCanvasEx Retina display problem(Dragging of elements is linearly slower with increasing editors area)
Re: FXCanvasEx Retina display problem [message #1752493 is a reply to message #1752479] |
Tue, 24 January 2017 13:38 |
Hi Miroslav,
thank you very much for reporting the issue in such detail. We noticed a delay with large viewports some time ago, but did not narrow down the reason for the delay, yet. Now that we know where to look (FXCanvasEx), I created a Bugzilla ticket [1] and will make a few tests to identify the performance killer (probably SWT redraw/update).
The inconveniences resolved by FXCanvasEx in contrast to FXCanvas, are forwarding of mouse wheel scroll and gesture events from SWT to JavaFX, consuming of already processed SWT events before forwarding them to JavaFX, correctly changing the mouse cursor, and ensuring that the canvas is redrawn even though many events are being dispatched. If you do not need to process gesture events etc., you can safely use FXCanvas until the issue is resolved.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=510946
Matthias
Re: FXCanvasEx Retina display problem [message #1752518 is a reply to message #1752493] |
Tue, 24 January 2017 16:18 |
Hi Miroslav,
the delay is not as significant or noticeable on my machine as it is on your machine, given the comparison gif. However, I experimented with calling SWT redraw/update from within the event dispatcher and found that calling redraw() without calling update() yields the best performance while still ensuring that the canvas stays responsive (as it is reasonably often redrawn). I asked Alexander to try the change out on his machine (which is a Mac), and we found that it improves performance significantly on a retina display. The fix will be available with GEF 5.0.0 M5. For the time being, you can create a replacement class (FXCanvasExEx) to replace the relevant code, as follows:
public class FXCanvasExEx extends FXCanvasEx {
private final class RedrawingEventDispatcher implements EventDispatcher {
private static final int REDRAW_INTERVAL_MILLIS = 40; // i.e. 25 fps
private EventDispatcher delegate;
private long lastRedrawMillis = System.currentTimeMillis();
protected RedrawingEventDispatcher(EventDispatcher delegate) {
this.delegate = delegate;
public Event dispatchEvent(final Event event, final EventDispatchChain tail) {
// dispatch the most recent event
Event returnedEvent = delegate.dispatchEvent(event, tail);
// update UI
long millisNow = System.currentTimeMillis();
if (millisNow - lastRedrawMillis > REDRAW_INTERVAL_MILLIS) {
redraw();
lastRedrawMillis = millisNow;
// return dispatched event
return returnedEvent;
protected EventDispatcher dispose() {
EventDispatcher d = delegate;
delegate = null;
return d;
private ChangeListener<Cursor> cursorChangeListener = ReflectionUtils.getPrivateFieldValue(this,
"cursorChangeListener");
public FXCanvasExEx(Composite parent, int style) {
super(parent, style);
public void setScene(Scene newScene) {
Scene oldScene = getScene();
if (oldScene != null) {
// restore original event dispatcher
EventDispatcher eventDispatcher = oldScene.getEventDispatcher();
if (eventDispatcher instanceof RedrawingEventDispatcher) {
oldScene.setEventDispatcher(((RedrawingEventDispatcher) eventDispatcher).dispose());
oldScene.cursorProperty().removeListener(cursorChangeListener);
super.setScene(newScene);
if (newScene != null) {
// wrap event dispatcher
newScene.setEventDispatcher(new RedrawingEventDispatcher(newScene.getEventDispatcher()));
newScene.cursorProperty().addListener(cursorChangeListener);
Matthias
Re: FXCanvasEx Retina display problem [message #1752575 is a reply to message #1752518] |
Wed, 25 January 2017 09:26 |
Miroslav Stefanovic Messages: 4 Registered: January 2017 |
Hi Matthias,
thanks for trying to help. I have tried code spinet above but something is wrong.
private ChangeListener<Cursor> cursorChangeListener = ReflectionUtils.getPrivateFieldValue(this, "cursorChangeListener");
'cursorChangeListener' object that you are trying to get using reflection is NULL. Later it's propagated as NPE in method
[Updated on: Wed, 25 January 2017 09:28] Report message to a moderator
Re: FXCanvasEx Retina display problem [message #1752580 is a reply to message #1752575] |
Wed, 25 January 2017 10:12 |
I tried to apply changes directly in new class (without extending FXCanvasEx) and I got what I wanted
Thanks a lot guys.
import java.lang.reflect.Method;
import org.eclipse.gef4.common.reflect.ReflectionUtils;
import org.eclipse.gef4.fx.swt.canvas.FXCanvasEx;
import org.eclipse.gef4.fx.swt.gestures.SWT2FXEventConverter;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.DisposeEvent;
import org.eclipse.swt.events.DisposeListener;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.Composite;
import javafx.beans.value.ChangeListener;
import javafx.beans.value.ObservableValue;
import javafx.embed.swt.FXCanvas;
import javafx.embed.swt.SWTFXUtils;
import javafx.event.Event;
import javafx.event.EventDispatchChain;
import javafx.event.EventDispatcher;
import javafx.scene.Cursor;
import javafx.scene.ImageCursor;
import javafx.scene.Scene;
import javafx.stage.Window;
protected RedrawingEventDispatcher(final EventDispatcher delegate)
final Event returnedEvent = delegate.dispatchEvent(event, tail);
// update UI
final long millisNow = System.currentTimeMillis();
redraw();
final EventDispatcher d = delegate;
delegate = null;
return d;
private ChangeListener<Cursor> cursorChangeListener = new ChangeListener<Cursor>()
public void changed(final ObservableValue<? extends Cursor> observable, final Cursor oldCursor, final Cursor newCursor)
// XXX: SWTCursors does support image cursors yet
// (https://bugs.openjdk.java.net/browse/JDK-8088147); we compensate
// this here (using JDK-internal API)
if (newCursor instanceof ImageCursor)
// custom cursor, convert image
final ImageData imageData = SWTFXUtils.fromFXImage(((ImageCursor) newCursor).getImage(), null);
final double hotspotX = ((ImageCursor) newCursor).getHotspotX();
final double hotspotY = ((ImageCursor) newCursor).getHotspotY();
final org.eclipse.swt.graphics.Cursor swtCursor = new org.eclipse.swt.graphics.Cursor(getDisplay(), imageData, (int) hotspotX, (int) hotspotY);
// FIXME [JDK-internal]: Set platform cursor on CursorFrame so
// that it can be retrieved by FXCanvas' HostContainer (which
// ultimately sets the cursor on the FXCanvas); unfortunately,
// this is not possible using public API.
try
final Method currentCursorFrameAccessor = Cursor.class.getDeclaredMethod("getCurrentFrame", new Class[] {});
currentCursorFrameAccessor.setAccessible(true);
final Object currentCursorFrame = currentCursorFrameAccessor.invoke(newCursor, new Object[] {});
// there is a spelling-mistake in the internal API
// (setPlatformCursor -> setPlatforCursor)
final Method platformCursorProvider = currentCursorFrame.getClass().getMethod("setPlatforCursor", new Class[] { Class.class, Object.class });
platformCursorProvider.setAccessible(true);
platformCursorProvider.invoke(currentCursorFrame, org.eclipse.swt.graphics.Cursor.class, swtCursor);
catch (final Exception e)
System.err.println("Failed to set platform cursor on the current cursor frame.");
e.printStackTrace();
private SWT2FXEventConverter gestureConverter = null;
private TraverseListener traverseListener = null;
private DisposeListener disposeListener;
* Creates a new {@link FXCanvasEx} for the given parent and with the given
* style.
* @param parent
* The {@link Composite} to use as parent.
* @param style
* A combination of SWT styles to be applied. Note that the
* {@link FXCanvas} constructor will set the
* {@link SWT#NO_BACKGROUND} style before passing it to the
* {@link Canvas} constructor.
public FXCanvasExEx(final Composite parent, final int style)
// XXX: As FXCanvas uses a dispose listener, we have to use the same
// mechanism here
disposeListener = new DisposeListener()
public void widgetDisposed(final DisposeEvent de)
// XXX: unset the scene, so event dispatcher and cursor listener
// are properly removed;
// XXX: The super class will also unset the stage as a result of
// unsetting the scene. The stagePeer will be unset through
// the host container when the stage is set invisible (which
// already happens through the dispose listener of the super
// class). The embedded scene (scenePeer) will be unset through
// the host container when unsetting the scene above;
setScene(null);
cursorChangeListener = null;
removeDisposeListener(disposeListener);
disposeListener = null;
removeTraverseListener(traverseListener);
gestureConverter.dispose();
addDisposeListener(disposeListener);
// create traverse
traverseListener = new TraverseListener()
public void keyTraversed(final TraverseEvent e)
if ((e.detail == SWT.TRAVERSE_TAB_NEXT || e.detail == SWT.TRAVERSE_TAB_PREVIOUS) && (e.stateMask & SWT.CTRL) != 0)
e.doit = true;
addTraverseListener(traverseListener);
gestureConverter = new SWT2FXEventConverter(this);
public void dispose()
// TODO: remove (logic has been put into dispose listener)
super.dispose();
* Returns the stage {@link Window} hold by this {@link FXCanvas}.
* @return The stage {@link Window}.
public Window getStage()
return ReflectionUtils.getPrivateFieldValue(this, "stage");
public void setScene(final Scene newScene)
final Scene oldScene = getScene();
final EventDispatcher eventDispatcher = oldScene.getEventDispatcher();
Miroslav
Current Time: Fri Apr 26 15:07:31 GMT 2024
Powered by FUDForum. Page generated in 0.03390 seconds
