Compatibility between plugins versions in Eclipse Mars [message #1752471] |
Tue, 24 January 2017 08:24 |
pierre durand Messages: 3 Registered: January 2017 |
Junior Member |
I use an Eclipse SDK, Mars 2 (4.5.2).
As I develop an Android application with JavafxPorts, I have added some plugins in Eclipse. All previous configurations worked fine.
After recently installing some plugins like Buildship (for more details, refer to http://stackoverflow.com/questions/41788999/after-installing-the-gluon-plugin-in-eclipse-sdk-mars2-the-gradle-task-view-is) .
Now, in Eclipse menu, the items about the Gradle tasks have changed, but they don't work. There are also some other errors.
It seems to be a compatibility problem between installed components in Eclipse (I hope so).
Main Eclipse SDK configuration:
- Buildship (Eclipse Plug-in for Gradle) : 2.0.1
- e(fx)clipse - IDE : 2.3.0
- Eclipse e4 tools : 4.5.1
- Eclipse SDK (Mars.2) : 4.5.2
- FileSync: 1.3.9
- Gluon Tools : 2.4.0
- JDepend4Eclipse : 1.2.4
- m2e (Maven) : 1.6.2
And, now, the failure context:
Plug-in: org.eclipse.equinox.p2.metadata.repository:
No repository found at http://marketplace.eclipse.org
No repository found at file:/C:/Users/pascal/AppData/Local/Android/sdk/buildshipArchive
No repository found at jar:file:/C:/Documents/Formations/Java/wkfx/appassembler-master.zip!/
Plug-in: org.eclipse.buildship.core
Synchronize Gradle projects with workspace failed due to an error connecting to the Gradle build.
Plug-in: org.eclipse.core.runtime AND Plug-in: org.eclipse.jface
Invalid input url:platform:/plugin/org.springsource.ide.eclipse.gradle.ui.taskview/icons/gradle-icon-16.png
After updating the Buildship:
Some internal and external locations could not be found.
No repository found at file:/C:/Users/pascal/AppData/Local/.
No repository found at jar:file:/C:/Documents/Formations/Java/wkfx/appassembler-master.zip!/.
No repository found at file:/C:/Users/pascal/AppData/Local/Android/sdk/buildshipArchive.
Unable to read repository at http://marketplace.eclipse.org/marketplace-client-intro?mpc_install=2496245.
http://marketplace.eclipse.org/marketplace-client-intro?mpc_install=2496245 is not a valid repository location.
No repository found at http://marketplace.eclipse.org.
Thanks a lot for your answer
Note: I tried to revert the recently done installations under Eclipse by using Help - Installation Details - Installation History and then by reverting one by one from the youngest to the oldest. But the third Revert action failed...
FUDForum. Page generated in 0.03179 seconds
