Re: ATL Metamodel [message #1751829 is a reply to message #1751763] |
Sun, 15 January 2017 14:54 |
The closest documentation is this: https://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Language
To learn more about how ATL text maps to the metamodel, you can inject your transformations into XMI models (requires ATL/EMFTVM to be installed):
- Right-click an ATL file, and select Open With -> Other...
- Select Sample Reflective Ecore Model Editor
- Select from the main menu File -> Save As...
- Choose a folder and file name ending in .xmi
Dennis
Re: ATL Metamodel [message #1753344 is a reply to message #1752846] |
Sat, 04 February 2017 09:30 |
Banafsheh Azizi Messages: 328 Registered: July 2016 |
In the ATL metamodel, we have "VariableExp" class with "name" attribute and "referredVariable" references to "VariableDeclaration" class with "varName" attribute. Can any one explain what are these elements?
I have also another questions, "oclExpression" contains all Expressions or just Expressions using ocl?
Is "Binding" Assignment Statement?
What is the difference between "BindingStat" and "Binding" classes?
Would you please make an example of "propertyName", attribute of "Binding" class?
Sorry for a lot of questions.
Many thanks for your time
Member of MDSE Research Group
http://mdse.ui.ac.ir
[Updated on: Sat, 04 February 2017 12:31] Report message to a moderator
FUDForum. Page generated in 0.04831 seconds
