Home » Eclipse Projects » Paho » MQTT PAHO C Library SSL(Does Paho C Library really supports SSL??)
MQTT PAHO C Library SSL [message #1751581] Wed, 11 January 2017 11:28 Go to next message
Our company used the MQTT Paho C Library in a project and the next step is to add support to SSL on it. We tried to work with SSL using the samples provided (unit test test5.cpp) but it really does not work, there is no SSL traffic on the wireshark we tried with many different brokers (sandboxes available on the web and it really does not work)
Do you guys are aware of any issues on the SSL implementation on the MQTT Paho C Library?
If there is no issue, is there any broker I can use? or any sample code that works ? I am using the Async version.
Paulo
Re: MQTT PAHO C Library SSL [message #1752055 is a reply to message #1751581] Wed, 18 January 2017 06:26 Go to previous messageGo to next message
I also have similar issue ssl support in paho mqtt c client is not working.It shows failed to connect error return code -1 when connected to apache activemq broker.Also no errors are displayed in broker's log.So I cant debug the code
Re: MQTT PAHO C Library SSL [message #1752504 is a reply to message #1752055] Tue, 24 January 2017 09:46 Go to previous messageGo to next message
Downloaded and compiled last github repo (cmake -g "Unix Makefiles" ... with SSL) with apparently no issues at compilation/install.
Ran the following command (Debian 7 with the last available libssl-dev)
./paho_cs_pub testssl --host test.mosquitto.org --port 8883 --qos 1
with TRACE on I get the following results
(same results with a different qos ... etc)
Using topic testssl
Trace Output
Product name: Paho Synchronous MQTT C Client Library
Version: 1.0.3
Build level: Tue Jan 24 11:00:54 UTC 2017
/proc/version: Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.65-1+deb7u2
Connecting
20170124 143701.979 3 publisher -> CONNECT cleansession: 1 (0)
20170124 143702.044 waitfor unexpectedly is NULL for client publisher, packet_type 2, timeout 28780
20170124 143703.147 3 publisher -> CONNECT cleansession: 1 (0)
20170124 143703.216 waitfor unexpectedly is NULL for client publisher, packet_type 2, timeout 27613
Failed to connect
Same results on several test brokers online.
Done several tests using the distributed samples.
I could connect successfully to the same brokers using node.js mqtt stuff - so this likely is an issue on the client side.
Using paho_c_pub etc. (no SSL) works.
Re: MQTT PAHO C Library SSL [message #1771080 is a reply to message #1752504] Mon, 21 August 2017 14:28 Go to previous message
check this link https://github.com/eclipse/paho.mqtt.cpp/issues/93
gcc mqttTest.c -o mqtttestc -l pthread -l paho-mqtt3as
Previous Topic:Unable to authenticate bluemix connection
Next Topic:Build paho c for iOS
Current Time: Tue Oct 28 12:05:22 EDT 2025
Powered by FUDForum. Page generated in 0.34606 seconds
