Home » Eclipse Projects » Eclipse Scout » Table and Disable Specific Cells if needed
Table and Disable Specific Cells if needed [message #1751534] Wed, 11 January 2017 04:15 Go to next message
Hello there,
if a certain value is set to a SmartColumn in my Table I'd like to disable it and set a static text instead of the stored value.
Is this somehow possible or can I only either enable or disable all cells at once?
Peter
[Updated on: Wed, 11 January 2017 04:18] by Moderator
Re: Table and Disable Specific Cells if needed [message #1751541 is a reply to message #1751534] Wed, 11 January 2017 05:27 Go to previous messageGo to next message
You can control what text is in the table cell using this callback. This example has a smart column of Locales.
When choosing "Deutsch" then it shows the cell text "Foo Bar" and the cell is not editable anymore.
Does that help?
          @Order(10)
          public class LanguageColumn extends AbstractSmartColumn<Locale> {
            protected boolean getConfiguredEditable() {
              return true;
            protected String getConfiguredHeaderText() {
              return TEXTS.get("Language");
            protected int getConfiguredWidth() {
              return 80;
            protected Class<? extends ILookupCall<Locale>> getConfiguredLookupCall() {
              return (Class<? extends ILookupCall<Locale>>) LocaleLookupCall.class;
            protected ILookupCall<Locale> prepareLookupCall(ITableRow row, final Locale key) {
              //'de' is special
              if (key != null && key.getLanguage().equals("de")) {
                //use special fixed text override, so emulate a single lookup row with the desired values
                ILookupCall<Locale> lookupCall = new LocalLookupCall<Locale>() {
                  protected List<? extends ILookupRow<Locale>> execCreateLookupRows() {
                    return Collections.singletonList(new LookupRow<Locale>(key, "Foo Bar"));
                lookupCall.setKey(key);
                return lookupCall;
              else {
                return super.prepareLookupCall(row, key);
            protected void execDecorateCell(Cell cell, ITableRow row) {
              final Locale key = this.getValue(row);
              //'de' is special, disable cell
                cell.setEditable(false);
Re: Table and Disable Specific Cells if needed [message #1751546 is a reply to message #1751541] Wed, 11 January 2017 05:42 Go to previous message
Great thanks, that looks very promising. I'll give that a try at the evening
Previous Topic:[NEON] Demo project
Next Topic:[neon] No bean returned
Current Time: Fri Sep 26 22:13:21 EDT 2025
Powered by FUDForum. Page generated in 0.13782 seconds
