Home » Modeling » Epsilon » Error when click on 'Generate GMF Editor'
Re: Error when click on 'Generate GMF Editor' [message #1751190 is a reply to message #1751182] |
Thu, 05 January 2017 14:03 |
C. Santos Messages: 32 Registered: September 2015 |
Member |
here is my .emf file:
@namespace(uri="crystal", prefix="crystal")
package crystal;
@gmf.diagram(foo="bar", rcp="false", onefile="true", diagram.extension="crystal")
class Crystal {
val Links[*] links;
val Subprograms[*] subprograms;
@gmf.node(figure="rectangle", border.width="1", label.readOnly="true")
abstract class Subprograms {
@gmf.compartment
val DataAbstractions[*] declarativePart;
@gmf.compartment
val Statements[*] executablePart;
abstract class NamedBlocks extends Subprograms {
attr String name;
@gmf.compartment
val DataAbstractions[*] parameters;
@gmf.node(label="name", label.text="Procedure", border.color="255,13,13")
class Procedure extends NamedBlocks {
@gmf.node(label="name", label.text="Function", border.color="25,191,108")
class Function extends NamedBlocks {
@gmf.compartment
val DataAbstractions[1] returnPart;
@gmf.node(label="description", label.text="Anonymous Block", border.color="43,106,215", border.style="dash")
class AnonymousBlock extends Subprograms {
attr String description;
@gmf.node(label="name", figure="rectangle", border.width="1", label.icon="true", label.readOnly="true", label.placement="internal")
abstract class DataAbstractions {
attr String name;
attr ParameterType type;
@gmf.node(label.text="Data Type")
class DataType extends DataAbstractions {
attr String className;
attr DataTypeOptions options;
attr int precision;
attr int scale;
@gmf.node(label.text="Collection")
class Collections extends DataAbstractions {
attr String code;
attr String typeName;
@gmf.node(label.text="Record")
class Records extends DataAbstractions {
attr String code;
@gmf.node(label.text="Cursor")
class Cursor extends DataAbstractions {
attr String cursorQuery;
@gmf.node(label="description", label.icon="true", label.placement="internal")
abstract class Statements {
attr boolean isStart;
@gmf.node(figure="rectangle")
abstract class CallBlocks extends Statements {
attr String nameSubroutine;
abstract class CursorOperations extends Statements {
attr String cursorName;
abstract class SQLOperations extends Statements {
attr String code;
abstract class IterationStructures extends Statements {
@gmf.compartment
val Statements[*] interations_statements;
abstract class ConditionalStructures extends Statements {
abstract class AdditionalOperations extends Statements {
class Expression extends AdditionalOperations {
attr String value;
class Exception extends AdditionalOperations {
attr String code;
class If extends ConditionalStructures {
attr String condition;
@gmf.compartment
val Statements[*] true_statements;
@gmf.compartment
val Statements[*] false_statements;
class Case extends ConditionalStructures {
@gmf.compartment
val Options[*] options;
@gmf.compartment
val Statements[*] default_statements;
@gmf.node(figure="rectangle", label="description", label.icon="true", label.placement="internal")
class Options {
@gmf.compartment
val Statements[*] case_statements;
class Insert extends SQLOperations {
class Update extends SQLOperations {
class Delete extends SQLOperations {
class Select extends SQLOperations {
class While extends IterationStructures {
class For extends IterationStructures {
attr String counter;
attr ForCounter typeCounter;
attr int lowestNumber;
attr int highestNumber;
class Loop extends IterationStructures {
attr String breakCondition;
class Open extends CursorOperations {
class Fetch extends CursorOperations {
attr String variableName;
class Close extends CursorOperations {
class CallProcedure extends CallBlocks {
class CallFunction extends CallBlocks {
abstract class Links {
@gmf.link(source="source", target="target", incoming="true", target.decoration="arrow", color="0,0,0", width="1", label="name", label.text="Statement Connection", label.icon="true")
class Transition extends Links {
attr String name;
ref Statements source;
ref Statements target;
@gmf.link(source="source", target="target", incoming="true", target.decoration="arrow", style="dash", color="0,0,0", width="1", label="name", label.text="Case Connection", label.icon="true")
class OptionsTransition extends Links {
attr String name;
ref Options source;
ref Options target;
enum ParameterType {
IN = 0;
OUT = 1;
IN_OUT = 2;
enum ForCounter {
NORMAL = 0;
REVERSE = 1;
enum DataTypeOptions {
CHAR = 0;
NCHAR = 1;
NVARCHAR2 = 2;
VARCHAR2 = 3;
LONG = 4;
RAW = 5;
LONG_RAW = 6;
NUMBER = 7;
NUMERIC = 8;
FLOAT = 9;
DEC = 10;
DECIMAL = 11;
INTEGER = 12;
INT = 13;
SMALLINT = 14;
REAL = 15;
DOUBLE = 16;
DATE = 17;
TIMESTAMP_WITH_TIME_ZONE = 18;
TIMESTAMP_WITH_LOCAL_TIME_ZONE = 19;
INTERVAL_YEAR_TO_MONTH = 20;
INTERVAL_DAY_TO_SECOND = 21;
BFILE = 22;
BLOB = 23;
CLOB = 24;
NCLOB = 25;
ROWID = 26;
UROWID = 27;
Re: Error when click on 'Generate GMF Editor' [message #1751191 is a reply to message #1751190] |
Thu, 05 January 2017 14:16 |
This works fine on my side. Could you please try with the latest interim version and let me know if the problem persists? If you have installed Epsilon on top of an existing distribution, could you please also double-check that you have fully installed GMF Tooling?
Dimitris
Current Time: Sat Sep 21 08:34:56 GMT 2024
Powered by FUDForum. Page generated in 0.04975 seconds
