Home » Modeling » QVT-OML » set XMI id of object during a QVTo transformation
set XMI id of object during a QVTo transformation [message #1751073] Wed, 04 January 2017 05:03 Go to next message
Hello everybody,
I would like to set xmi id to the objects created by my transformation (I will reuse when possible the id of my source model).
I know that QVTo doesn't work on XMIResource directly, but on ModelExtent, so it seems me not possible to do it during the transformation itself. Please someone can confirm me this point ?
I think I will create a map in a blackbox with the target objects and their ids during the transformation and apply them when the created objects are stored in the final XMI resource, but it seems dirty.
Do you have any opinion about this way ?
Vincent Lorenzo
Re: set XMI id of object during a QVTo transformation [message #1751080 is a reply to message #1751073] Wed, 04 January 2017 05:48 Go to previous message
HI Vincent
This is a FAQ for which I raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=485439
xmi:id is not a model attribute, it is therefore invisible to modeling tools. Today, if you have a non-modeling requirement, you need to implement it in the non-modeling support. Probably in your XXXResource.save path.
Ed Willink
Previous Topic:Refine profiled model in QVT-OML
Next Topic:Serialization of QVT-O Traces
Current Time: Sun Nov 09 18:36:13 EST 2025
Powered by FUDForum. Page generated in 0.03679 seconds
