Home » Eclipse Projects » Eclipse Scout » Assertion error: No userId available
| Assertion error: No userId available [message #1751002] |
Tue, 03 January 2017 10:21  |
Hello everyone!
We've been using eclipse scout for a while now, and are quite happy with it.
While testing our application, we discovered following behaviour:
1) We authenticate (login) with User A.
2) Application loads, everything works.
3) Seconds later, we authenticate (in other browser, or even on other computer) with another User B.
4) Application start fails with "Initialization failed"
This behaviour does only occour when application runs on a Tomcat (Windows Server). Within eclipse this never happends!
The error logged says "No userId available". See full stack trace:
org.eclipse.scout.rt.platform.util.Assertions$AssertionException: Assertion error: No userId available [user=admin, calling-thread=https-jsse-nio-8443-exec-4, job=Starting ClientSession [sessionId=758019ed-6fc6-4f16-8c25-0c7c13f11c04]]
at org.eclipse.scout.rt.platform.util.Assertions.fail(Assertions.java:580)
at org.eclipse.scout.rt.platform.util.Assertions.assertNotNull(Assertions.java:87)
at org.eclipse.scout.rt.client.clientnotification.ClientSessionRegistry.checkSession(ClientSessionRegistry.java:105)
at org.eclipse.scout.rt.client.clientnotification.ClientSessionRegistry.sessionStarted(ClientSessionRegistry.java:98)
at org.eclipse.scout.rt.client.clientnotification.ClientSessionRegistry.sessionChanged(ClientSessionRegistry.java:223)
at org.eclipse.scout.rt.client.AbstractClientSession.fireSessionChangedEvent(AbstractClientSession.java:646)
at org.eclipse.scout.rt.client.AbstractClientSession.start(AbstractClientSession.java:328)
at org.eclipse.scout.rt.client.session.ClientSessionProvider$1$1.call(ClientSessionProvider.java:81)
at org.eclipse.scout.rt.client.session.ClientSessionProvider$1$1.call(ClientSessionProvider.java:1)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:185)
at org.eclipse.scout.rt.platform.context.RunContextRunner$1.call(RunContextRunner.java:42)
at org.eclipse.scout.rt.platform.security.SubjectProcessor$1.run(SubjectProcessor.java:47)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:180)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:135)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:121)
at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask$1.call(JobFutureTask.java:100)
at java.util.concurrent.FutureTask.run(Unknown Source)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:160)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:54)
Somebody posted the same issue, I tried to get rid of it using thier inputs - unfortunately without success.
https://www.eclipse.org/forums/index.php/t/1081251/
We've done a lot of work managing users, since we have a special setup where every user should have it's own database. So I thought, maybe we broke something or our code is causing this issue.
To check this, I created a complete new scout project in an empty workspace and deployed it without modifications on the tomcat server.
I logged in with scott/tiger, opened another browser and tired to login as admin/admin. Exactly the same issue occured, which indicates that there must be another problem besides the code.
What we are using:
Windows Server 2012
Apache Tomcat/9.0.0.M9
Java 8
org.eclipse.scout.rt.version: 6.0.200.0
Access to server can be granted if needed.
Do you have an idea what is causing this issue? Might Tomcat 9 be incompatible?
Best regards
Kevin
UPDATE:
Using Tomcat 8 this issue does not occour, so it might really be incompatible with version9.
[Updated on: Tue, 03 January 2017 13:08] by Moderator
| Re: Assertion error: No userId available [message #1752699 is a reply to message #1751532] |
Thu, 26 January 2017 04:48   |
Hi Beat
Meanwhile I've setup the productive enviroment, which now is using Ubuntu 16.04 (should not be important here).
During this setup, I encountered again the same issue. As I thought that it's something related to Tomcat 9.x I installed Tomcat 8.5.11 to prevent this issue.
When the enviroment was set up and I made the very first deployment, I was able to observe the exact same behaviour as described above (second login ends in "Initialization failed").
A bit frustrated I reinstalled tomcat, now version 8.0.41 - were this issue never appears. Thus, I assume something from 8.0 to 8.5 is causing this behaviour. (see update: it appears after a while also on 8.0.41, so nothing to do with that)
To answer your questions and give some informations:
1) It's the only scout application deployed (client and server)
2) Clearing tmp and work dir did not solve this issue
3) We are using database auth
4) Tomcat config is basically standard - nothing special
5) I did not test the contacts app on the productive enviroment as I did before
6) It can be reproduced, it's not something happening sporadically
For now, using 8.0 solves this - but it doesn't feel good being not able to update. If you still are unable to reproduce, I can provide you a instance to do so (if you're intrested in).
UPDATE:
Was a bit to fast, it's not solved - I've now read that server and client should be hosted on different machines (in production), however it is not supposed to crash on one right? One scout application is in my understanding server and client.
Best regards
Kevin
[Updated on: Thu, 26 January 2017 09:26] by Moderator
| Re: Assertion error: No userId available [message #1752777 is a reply to message #1752699] |
Fri, 27 January 2017 03:27   |
Kevin,
I'm very sorry that you are experiencing so much trouble. I know that those problems can be quite frustrating.
Because the issue you describe sounded quite serious, I had another look at it. Unfortunately, I could not reproduce it with the following setup:
- Versions:
- Eclipse Scout SDK: Neon.2 Release (4.6.2); Build id: 20161208-0600
- Scout version: 6.0.200.0
- Java: Java(TM) SE Runtime Environment (build 1.8.0_31-b13); Java HotSpot(TM) 64-Bit Server VM (build 25.31-b07, mixed mode)
- I created a "Scout Hello World" application using the "New Project" wizard. The only thing I changed was the server connection in the config.properties (http instead of https, port 8080) and I removed the <secure> flag from web.xml, as describe here: http://eclipsescout.github.io/6.0/beginners-guide.html#update-the-scout-application-to-work-with-http
- I downloaded the standalone ZIPs for Apache Tomcat, versions apache-tomcat-8.5.11-windows-x64 and apache-tomcat-9.0.0.M15-windows-x64, respectively. (I did not notice any differences between the two.)
- Then I built the helloworld app using Maven and dropped the two war files into the webapps folder.
- Login in Chrome with scott:tiger -> ok. Then login in Firefox (definitively a different browser) with admin:admin -> ok. Both instances were working as expected.
I did my test on Windows, but this should not have any influence. Is it possible that the database authentication module you use has something to do with it?
Running server and client/UI on the same appserver is perfectly fine. Only running two UI apps on the same server will cause problems. Different servers can help distributing the load in a clustered environment (e.g. 1 server node and multiple UI nodes).
I have attached the two *.war files I used for my test. Maybe you can try them out in your environment and check for any differences.
Beat
| Re: Assertion error: No userId available [message #1752796 is a reply to message #1751002] |
Fri, 27 January 2017 07:02   |
Hello Beat
First of all, we're very thankful for your effort to help.
Important clarification
When I created this thread, I posted the StackTrace containing a message like "Assertion error: No userId available". As mentioned above, we then changed to tomcat 8.0.39/8.0.41 - which we thought solved the issue. As we've learned from the referenced thread, were the same exception was mentioned, they solved it by making sure not to deploy two client .wars to the same tomcat instance. It is possible, that at the time I created this thread, we maybe had two clients deployed (by mistake or maybe we didn't cleared the work or temp folders). This would explain why it later worked with a fresh installation of tomcat, since there was nothing deployed before.
Today's status
I think, we were now able to locate the issue. During this week, we've build the productive enviroment - where we observed following behaviour:
1) Login of user A works
2) Login of user B in another browser fails with "Initialization failed"
3) As logged in user A, perform logout (/logout)
4) Login of any user works
5) Behaviour continuous at point 2)
So obviously, only one user is able to login simultaneously until the related session is destroyed. In the server.app.log we were also able to observe:
1) When first user performes login, a new server session is created
2) When second user tries to login, execLoadSession (ServerSession.java) is not performed - since LOG.info("created a new session for {}", getUserId()); is not printed and the very first SQL which is performed is the load of the first page.
This behaviour was the same as the initially posted one, but now there was no longer the message "Assertion error: No userId available".
The error, we are no struggling with is caused by the following vHost defined in conf/server.xml. Whith this, we want to achieve that the application is invoked by app.domain.com.<Host name="app.domain.com" appBase="webapps">
<Context path="/" docBase="ch.primesystems.kamugo.ui.html" />
</Host>
When we remove this vHost, it works as expected - if we add it, it's causing the above described issue/behaviour. Also, if we keep the vHost but access the whole path to the application it also works - so only if we access the host via the vHost it fails. This should be reproducible. What's maybe important:
- we use a Let's encrypt certificate, so SSL connections are used
- we force a redirect from http connections to https connections
Have you any input on how to properly use / define a vHost?
Best regards
Kevin
[Updated on: Fri, 27 January 2017 07:03] by Moderator
| Re: Assertion error: No userId available [message #1752815 is a reply to message #1752796] |
Fri, 27 January 2017 10:24  |
Kevin,
Ah, that special context configuration is indeed the cause of the error! Adding this definition has the same effect as adding a second UI application, with the same issues ("No userId available"). Why is that? Tomcat apparently always automatically deploys all webapps it finds in the "webapps" subdirectory. The special root context you are defining is additional. So the same webapp is started twice, which causes trouble because the JVM's cookie manager is a singleton.
From the Tomcat documentation (https://tomcat.apache.org/tomcat-8.5-doc/config/context.html):
"path: (...) Even when statically defining a Context in server.xml, this attribute must not be set unless either the docBase is not located under the Host's appBase or both deployOnStartup and autoDeploy are false. If this rule is not followed, double deployment is likely to result."
I see two solutions:
1. Try deploying your UI-WAR outside the "webapps" folder and then using a relative or absolute path in the "docBase" attribute:
<Context path="/" docBase="../special/org.eclipse.scout.apps.helloworld.ui.html" />
(Untested, but should work according to the documentation.)
2. Use Tomcat's default configuration and don't expose the tomcat server to the internet. Instead, use a separate reverse proxy server (Apache httpd and nginx seem to be quite popular) that transparently redirects incomming requests to the tomcat URL. This is probably the better solution for productive systems anyway.
Beat
Current Time: Mon Oct 27 03:57:41 EDT 2025
Powered by FUDForum. Page generated in 0.07759 seconds
