Home » Eclipse Projects » EclipseLink » Erro: Column name is being ignored(An exception was thrown while trying to Query. The EclipseLink is changes the field (column name) name by the the attribute name.)
icon5.gif  Erro: Column name is being ignored [message #1750931] Mon, 02 January 2017 07:03 Go to next message
Versions:
NetBeans - 8.1
EclipseLink - 2.5.2
Postgresql - 9.1
GlassFish Server 4
I don't know why, but note that t2.id should be t2.pess_id, but EclipseLink changes the column name by the attribute.
Someone can help me?
Detalhado:   SELECT comp_cota_id, alte_em, alte_por_id, comp_cota_situ, cria_em, cria_por_id, dscr, praz_entr_cota, empr_unid_id, usua_id FROM comp_cota
Detalhado:   SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))
	bind => [3, EmpresaUnidade]
Detalhado:   SELECT 1
Advertência:   Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.postgresql.util.PSQLException: ERROR: column t2.id does not exist
  Posição: 459
Error Code: 0
Call: SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))
Query: ReadObjectQuery(name="empresaUnidadeParaCotacao" referenceClass=EmpresaUnidade sql="SELECT t0.pess_id, t0.cadastro_tipo, t0.alte_em, t0.alte_por_id, t0.anfi, t0.apel_nome_fant, t0.ativ, t0.cada_tipo, t0.clie, t0.cons_fat_min, t0.cria_em, t0.cria_por_id, t0.forn, t0.nasc_fund, t0.nome_raza_soci, t0.obs, t0.pess_tipo, t0.pess_grup_id, t1.pess_id, t1.alte_em, t1.alte_por_id, t1.cpf_cnpj, t1.cria_em, t1.cria_por_id, t1.rg_ie, t2.pess_id, t2.alte_em, t2.alte_por_id, t2.cria_em, t2.cria_por_id FROM pess t0, empr_unid t2, pess_cada t1 WHERE ((t2.id = ?) AND (((t2.pess_id = t0.pess_id) AND ((t1.pess_id = t0.pess_id) AND (t1.pess_id = t0.pess_id))) AND (t0.cadastro_tipo = ?)))")
	at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:340)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:679)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:558)
	at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1995)
	at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:570)
	at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:248)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:242)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:228)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:714)
	at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2777)
	at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2730)
	at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:526)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1155)
	at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:899)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1114)
	at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:429)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1202)
	at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2894)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1797)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1779)
	at org.eclipse.persistence.internal.indirection.NoIndirectionPolicy.valueFromQuery(NoIndirectionPolicy.java:326)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRowInternal(ForeignReferenceMapping.java:2234)
	at org.eclipse.persistence.mappings.OneToOneMapping.valueFromRowInternal(OneToOneMapping.java:1790)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRow(ForeignReferenceMapping.java:2120)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.buildCloneFromRow(ForeignReferenceMapping.java:336)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoWorkingCopyClone(ObjectBuilder.java:1811)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneFromRow(ObjectBuilder.java:1958)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:726)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:629)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:587)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:571)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:782)
	at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:848)
	at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:490)
	at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:402)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1744)
	at org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:258)
	at org.eclipse.persistence.internal.jpa.QueryImpl.getResultList(QueryImpl.java:468)
	at net.cartola.logic.CompraCotacaoLogic.list(CompraCotacaoLogic.java:99)
	at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1081)
	at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1153)
	at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:4695)
	at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:630)
	at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:822)
	at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:582)
	at org.jboss.weld.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:46)
	at sun.reflect.GeneratedMethodAccessor302.invoke(Unknown Source)
	at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:883)
	at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doCall(SystemInterceptorProxy.java:163)
	at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:140)
	at sun.reflect.GeneratedMethodAccessor301.invoke(Unknown Source)
	at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:369)
	at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:4667)
	at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:4655)
	at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:212)
	at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
	at com.sun.proxy.$Proxy343.list(Unknown Source)
	at net.cartola.wms.cotacao.CotacaoBean.listarTodasCotacoes(CotacaoBean.java:288)
	at net.cartola.wms.cotacao.CotacaoBean.pesquisar(CotacaoBean.java:278)
	at javax.el.ELUtil.invokeMethod(ELUtil.java:326)
	at javax.el.BeanELResolver.invoke(BeanELResolver.java:536)
	at javax.el.CompositeELResolver.invoke(CompositeELResolver.java:256)
	at com.sun.el.parser.AstValue.invoke(AstValue.java:269)
	at com.sun.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:304)
	at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105)
	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:87)
	at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
	at javax.faces.component.UICommand.broadcast(UICommand.java:315)
	at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:790)
	at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1282)
	at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81)
	at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
	at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:198)
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:646)
	at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1682)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:344)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:214)
	at org.netbeans.modules.web.monitor.server.MonitorFilter.doFilter(MonitorFilter.java:393)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:316)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:160)
	at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:734)
	at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:673)
	at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:99)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:174)
	at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:357)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:260)
	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:188)
	at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:191)
	at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:168)
	at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:189)
	at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:288)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:206)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:136)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:114)
	at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77)
	at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:838)
	at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:113)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:115)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:55)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:135)
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:564)
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:544)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.postgresql.util.PSQLException: ERROR: column t2.id does not exist
  Posição: 459
	at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2284)
	at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2003)
	at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:200)
	at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:424)
	at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:161)
	at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:114)
	at sun.reflect.GeneratedMethodAccessor280.invoke(Unknown Source)
	at org.postgresql.ds.PGPooledConnection$StatementHandler.invoke(PGPooledConnection.java:426)
	at com.sun.proxy.$Proxy337.executeQuery(Unknown Source)
	at com.sun.gjc.spi.jdbc40.PreparedStatementWrapper40.executeQuery(PreparedStatementWrapper40.java:642)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:1002)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:641)
	... 127 more
The files follow attached
Re: Erro: Column name is being ignored [message #1751313 is a reply to message #1750931] Sat, 07 January 2017 15:39 Go to previous message
This is a rather complex SQL statement with no context of the entity or JPA query that formed it. More information would help (the entities involved, the query etc) as would testing to see if this issue occurs on simpler queries involving the entity mapped to the empr_unid table.
Previous Topic:The DB2 platform/dialect is inefficient, out of date and inexact
Next Topic:Eclipselink: batch reading creates a lot of queries
Current Time: Thu Nov 06 07:55:43 EST 2025
Powered by FUDForum. Page generated in 0.04472 seconds
