| Moxy - return class type for XML element [message #1750832] |
Thu, 29 December 2016 13:51  |
xpath = "/msg:L1MessageRequest/msg:Header";
val = jaxbContexL1.getValueByXPath(message.getPayload(), xpath, resolver, Object.class);
I am getting null value back from call to getValueByXPath() method when I try to pass in an expression that should be returning an XML set of elements. for example, returning:
<msg:Header>
<hdr:MsgID>LA00000000000110wAA11111</hdr:MsgID>
<hdr:MsgType>request</hdr:MsgType>
<hdr:MsgTimestamp>2016-01-05T09:00:00-04:00</hdr:MsgTimestamp>
.. more stuff ...
</msg:Header>
Since I do not know what the expected return type is, I just passed in Object.class, but not sure if that is the problem. Does anyone know what java type's class I should be using to return an XML fragment?
Thanks.
FUDForum. Page generated in 0.03247 seconds
