Re: Setting up Indigo with Xtext [message #1750280 is a reply to message #1750276] |
Mon, 19 December 2016 13:13 |
The current release of Xtext is targeted for Eclipse Luna, so you will have to install a previous version.
In the "Install new software" dialog deselect "Show only the latest versions..." option.
Eclipse Indigo was packaged with Xtext 2.0.1, that version will be compatible for sure. Any newer is untested, the platform is just too old.
You could also just use http://download.eclipse.org/releases/indigo as an update site, without the Xtext releases repo. There you would have automatically Xtext 2.0.1.
There are good chances that you could install a newer version also, just try the versions backward.
FUDForum. Page generated in 0.26914 seconds
