Issue during Eclipse workspace setup [message #1750215] |
Sun, 18 December 2016 19:37 |
I'm trying to setup the Eclipse workspace for XText.
I'm following the instructions at:
https://github.com/eclipse/xtext/blob/master/CONTRIBUTING.md#set-up-your-eclipse-workspace
Everything goes well until the xtext-umbrella repository is cloned:
Performing Git Clone git@github.com:eclipse/xtext-umbrella.git (master)
Cloning Git repo git@github.com:eclipse/xtext-umbrella.git to C:\Users\Eric\xtext-master\git\xtext-umbrella
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/xtext-umbrella.git: Auth fail
I'm pretty sure I entered my credentials correctly (User ID have numbers only) and am wondering what I am doing wrong. Down the error message, it seems that oomph tries to clone over git-ssh, and I get confused as to what I should try next.
How are you guys setting the Eclipse workspace?
Btw I'm on Windows 64-bit.
[Updated on: Sun, 18 December 2016 19:38] Report message to a moderator
Re: Issue during Eclipse workspace setup [message #1750269 is a reply to message #1750217] |
Mon, 19 December 2016 12:08 |
That is what I did:
1) Create an SSH key with puttygen
2) Install the public key in my Github account
3) Tell Oomph installer to use my private key
And it worked!
It would be nice to update the instructions to mention about the fact that an SSH key is needed. All these steps are not obvious for people who are not coming from the eclipse world.
Now I'm scratching my head as to how I can build the Idea plugin.
Re: Issue during Eclipse workspace setup [message #1753637 is a reply to message #1753633] |
Wed, 08 February 2017 11:20 |
Dariusz Dziuda Messages: 3 Registered: February 2017 |
The real issues are (or may be) probably:
!MESSAGE Project org.eclipse.xtext.license.feature exists in different location: /home/ddziuda/eclipse/xtext-master/git/xtext-umbrella/releng/org.eclipse.xtext.license.feature
!MESSAGE Problem parsing archive:file:/!/home/ddziuda/eclipse/xtext-master/git/xtext-xtend/org.eclipse.xtend.maven.android.archetype/src/main/resources/archetype-resources/.project
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtend:org.eclipse.xtend.core:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.xbase.lib:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.util:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtext:org.eclipse.xtext.smap:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE org.eclipse.m2e.core.internal.embedder.EclipseLogger - The POM for org.eclipse.xtend:org.eclipse.xtend.lib:jar:2.12.0-SNAPSHOT is missing, no dependency information available
!MESSAGE Done
!STACK 0
org.xml.sax.SAXException: Done
at org.eclipse.emf.ecore.plugin.EcorePlugin$1Handler.startElement(EcorePlugin.java:383)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scanRootElementHook(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformPluginToPlatformResourceMap(EcorePlugin.java:460)
at org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformURIMap(EcorePlugin.java:571)
at org.eclipse.xtext.ui.resource.JavaProjectResourceSetInitializer.computePlatformURIMap(JavaProjectResourceSetInitializer.java:60)
at org.eclipse.xtext.ui.resource.JavaProjectResourceSetInitializer.initialize(JavaProjectResourceSetInitializer.java:50)
at org.eclipse.xtext.ui.resource.XtextResourceSetProvider.get(XtextResourceSetProvider.java:51)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:284)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:319)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:155)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:487)
at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:399)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$4.run(SetupTaskPerformer.java:3350)
But github authentication succeeded so I don't know what causes it.
Any hints?
FUDForum. Page generated in 0.05262 seconds
